| Stripper wanted... (some people will do anything to get their posts read!) Paint Stripper question... If I had an Aluminium hull faired with a little filler then coated with a well adhered 2 part epoxy primer - that has then later been painted with a single pack paint that has not adhered to the 2 pack propery and has started to come off. - Any ideas what I could use to strip off the top one and leave the 2 part intact? Info greatfully received... |
| Heh heh!! Cute.......... |
| Re Heh heh!! Cute.... - yes she does have a nice bottom...! Any paint engineers out there? |
| I've had afew jobs like this . 2 options - sand off with least dammaging grade of paper to achiene the required result . being the "softer " product the single pack will come away realativly easily, or 2 sponge blast - a propriety blast system that uses a soft medium. does acieve good results but is expensive. what ever ,its messy |
| Just a guess, but I have used acetone, a lot of rags and time in the past (It does not affect epoxy primers) but of course it's not the most friendly substance known to man kind. Another idea is a heat gun. The Primer will usually withstand much higher heats than a sinle pack paint. |
| You might try using the stripper from Star10, think it's called Dan Swett's paint remover. It's entirely solvent, but no caustics, if you only work on a small area and work quick it'll remove the paint without touching the epoxy under it. |
| power boat molds wanted | bill johnson | Boat Molds | 2 | 11-30-2010 11:39 PM |
| Draft Person Wanted - Antibes France | Services & Employment | 7 | 03-09-2006 11:36 AM | |
| Photos of Cruise Ships, Yachts, Tankers etc wanted! | Yachting | Marketplace | 1 | 10-28-2004 04:48 PM |
| Help Wanted: Westlawn Alumni to Celebrate 75th Anniversary! | dgerr | Education | 0 | 10-19-2004 11:10 AM |
| Experienced Naval Architecture Wanted | Services & Employment | 2 | 03-16-2004 06:04 AM | |
