Old 08-29-2005, 09:44 AM
jfblouin's Avatar
jfblouin jfblouin is offline
Rep: 24 Posts: 163
Strengh of 24 oz woven vs 15.2 oz Bi-axe
Hi
Does some body can inform me if 24 oz woven roving in epoxy is stronger of 15.2 oz 0-90 Bi-axe in epoxy too ?
I can have a roll of 24 oz woven roving at very low cost.
Jean-Francois Blouin
PS Sorry for my not so good english
Old 08-31-2005, 03:12 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
The roving should be stronger, but do not forget to account for the extra weight/cost of the extra epoxy you will need to wet out the roving.
My guess is that it will take about 3/4 pound more in epoxy per square yard. With epoxy at say $58 you spend more than $4 a square yard more to wet out that "cheaper" material - not to mention the boat now weighs more than it needs to. Very rough math done in my head, so it could be off - but even if its far off, you see the point
Old 09-25-2005, 10:56 AM
michael-compwes michael-compwes is offline
Rep: 10 Posts: 19
the cloths you're comparing have 60% weight difference,,but with the better engineering of biax ,I'll think the 2 cloths are pretty comparable in their strengths............PLUS the weave in the roving also absorbs more resin per it's strength,,,,,so I'd say you're quite possibly going to double your resin consumption ,,price of resin,,,AND weight.,for the same strength.
.......a good supplier will be able to specify what biax would compare with the roving.
Old 10-01-2005, 01:27 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Jean-Francois,
If the two fabrics are made with the same type of glass, the tensile strength is proportional to the weight of the fabric. However, if you pull an individual strand of glass from the edge of a roving fabric, you'll see that it has little wiggles from being woven. But, if you pull a strand from a biax fabric, you'll find that it is straight.
That difference has two effects. The roving will be less stiff, because when you put a load on it, the fibers tries to straighten out first before they begin to stretch. And, because of the roving being woven, the fibers aren't as efficiently packed together as in the biax, and consequently it ends up being thicker and with more resin in it than a layup with the same weight of biax.
This explanation is of course quite simplified, but I don't have all night.
Yoke.
Old 10-04-2005, 08:30 AM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Thanks for this topic as it appears I will have to lay up my own 1/4" ply for hull skins to get a thick enough inner and outer skin for sanding, staining and varnishing. 1/8" inner and outer plies with a rigid cloth in between for glueing and puncture resistance to allow enough time to safely abandon ship.
Old 10-04-2005, 10:56 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,647
What Yoke said. It depends on what you mean by "strength".
Tom Lathrop
Old 10-06-2005, 01:43 AM
Boatbuilder
Rep: 15 Posts: 545
Tom, tensile strength of dry glass along the fibers. As stated, a very simplified explanation, especially the bit about the roving fibers only straightening before stretching in a laminate, but I hope you get the drift.
Yoke.
