| Stitch and Glue Boat - HELP!!! Talked with a supply company about building a stitch and glue boat. Was told not to buy Epoxy resin unless using for scarf joints, because of the heat in Florida would make the fiberglass too flexible. Please Help! (Every boat builder set of plans I have looked at says Epoxy resin not Polyester for fiberglass work and scarf joints) |
![]() ![]() ![]() ![]() Polyester is a laminating material not a glue !! doesnt matter what you mix with it !!! ![]() ![]()
Polyester 'can' be a good laminating resin but can't match it with a good epoxy. I've been using epoxy for 'stich-&-glue' for over 30 years & never had a failure - both in my personal life [in building 'A' & 'B' class catamarans] & in my boat building & repair business. 'Tunnels' got it totally right - use epoxy is your only successful choice!! Good luck with your project. Ciao, james |
| The taped seam (stitch and glue, etc.) building methods wouldn't exisit without the elongation and peel strength properties of epoxy. No other resin system can compare or should be considered. I'm in Florida (not very far from you) and I don't have issues with 'glass or epoxy use, so the best advice you could receive, is to stop listening to the supplier, offering advice on things they don't understand. Who was this "supply company"? |
| Thank You Tunnels, Silver Raven and PAR for setting my mind at ease. When I first received the information, I was completely in Shock!!! |
| In Shock about being told to use polyester over Epoxy, when all my notes and findings read "Epoxy". Thanks again. |
| I would find a different "supply company". Welcome to the forum.
__________________ Hoyt The TITANIC sank because it had a hole in it(still does). Submarine Tom You just can't put too much info on your patterns. DGreenwood |
Florida, in fact, is one of the best places in the country to use epoxy because you can get it to kick fast enough (to full cure) to get some work done. The supplier seems to be getting all confused about HDT or something. |
| simple rule of thumb is Epoxy it the top of the resin ladder !! polyester is the bottom and vinylester is some where in between with simular properties of each is some cases!! Theres a long list of each and every one of these systems so dont just grab the first one you come to !! choose carefully and find the best of the best suited for your particular situation !!. Suppliers havent even found the trail to get to the evolutionary ladder yet so what can you exspect !!. ![]() ![]() ![]()
I have 3 different types of epoxy for my build because there are different situations for each (infusion, hand laminating glass and general bonding/fillet/coves, etc...). Also, my temperatures range from 40F at night in the winter to about 100+F during the day in the summer at times. It was important to have epoxy that covered those temperature variations as well as the different physical requirements of the build. Try to figure out how you will use the epoxy (sounds like doing biaxial tape jobs, coves and maybe sheathing the outside of the boat). One epoxy should work well for all of this, but make sure it has a flexible hardener system that allows you to work at any temperatures you might encounter and control the kick rate. Listening to Tunnel's advice there will make your build a lot easier. |
| OSB stitch and glue boat | And-Con | Wooden Boat Building and Restoration | 14 | 03-01-2010 10:47 AM |
| Stitch and Glue? | stonedpirate | Boatbuilding | 8 | 12-06-2009 10:46 PM |
| big stitch-and-glue boat | Little Iris | Wooden Boat Building and Restoration | 18 | 09-07-2007 06:34 PM |
| stitch an glue boat size.. | hob_n | Boatbuilding | 9 | 09-23-2005 11:03 AM |
| stitch and glue | Boatbuilding | 2 | 06-27-2002 09:33 PM | |
