Old 10-15-2005, 05:41 PM
zember311 zember311 is offline
Rep: 10 Posts: 16
standard sandable primer for plugs
Hello all!
Have a simple question for you... May be a no brainer, but I would like to be safe then sorry on this issue.
I have built several molds in the past / present, but I want to make it a bit simpler " time crunch "
In the past I make my plugs out of wood, spray them with gelcoat, sand them up to 2500, rub compound, wax, buff. ( 2500 is extreme, but it saves me from any mold inprefections )
so them it is the standard, PVA, then begin the gelcoat and lay-up..
on this plug I am building, I was thinking I could just spray the plug with primer, sand it smooth, buff then wax and polish before PVA then the rest as follows.
will a primer surface over wood ( several coats ) then polished work without any sticking issues? or should I stick to gelcoating the plug?
( just trying to find ways to save some time/money on these plugs.
thanks
Old 10-15-2005, 05:48 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
I can not give you a technical answer, but I can tell you to write down how many truthfull minutes each step takes. Have someone else on the stopwatch. When you finsh the job, review the actual time of each step. A detailed layout lets you zero in on steps to be attacked. I have found my first guesses wrong, once in a while.
Old 10-15-2005, 06:07 PM
Tactic Tactic is offline
Rep: 10 Posts: 87
I have used several coats of epoxy primer on plugs for model yacht hulls and decks.The process worked fine with no issues.
My process was as follows.
Manufacture plug from MDF board.
several coats of epoxy resin to seal.
3 coats of Epoxy primer sading between coats.
wax in the normal manner..PVA etc..mold layup.
Once on some production molds(again a small model) I used the system above but added a 2 pot finnshing coat(gloss black)
The production molds came out without flaws.
Old 10-15-2005, 08:04 PM
solutionguy solutionguy is offline
Rep: 10 Posts: 5
sandable primer
no problem i do that all the time I use a high build heavy solids automotive primer its three part very easy to use 4-1-1 sets like a rock is easy to sand and then wax like normal and use PVA any more questions c.hoggard@shaw.ca
Old 10-16-2005, 08:37 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Zember,
Duratec primer by Hawkeye industries, formulated for that particular purpose, and very easy to sand.
Yoke.
Old 10-18-2005, 06:33 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
PPG deltron used to work.Just make sure you use a suitable air-fed mask when spraying anything of this type.
Primer or paint instead of gel coat in a mold Doug Lord Fiberglass and Composite Boat Building 5 04-29-2005 08:53 PM
