Old 05-14-2011, 08:53 AM
Rep: 1493 Posts: 7,447
Welder/fitter: do you know at what temperature range is Monel magnetic?
Old 05-14-2011, 04:42 PM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
The most honest answer I could give to that is that I have no idea, but it is easy enough to look up. I had to learn a bit about it when I was a weld inspector for my father's consulting firm, back in the mid/late 1980s &, again, in the mid/late 1990s. My father was a metallurgical engineer whose clients, among others, included the shipyards that I worked for in later years. I recall that it depends on curie temperature resulting from the alloying, some of the series having such a low curie point that they would be insignificant to the discussion at hand, 400 series is slightly magnetic through room temperature, not, if heated. I was taught to, among other things, differentiate between Monel & other alloyed steels by the results of polishing, due to the lack of chromium.
Is your question based on an interest in the magnetic range of various Monel alloys, or just dick measuring? I wonder, as there are members far more qualified to answer your question than I. Like yourself, I'm just trying to help the OP as best I can.
Mike
Old 05-15-2011, 03:48 AM
davptt davptt is offline
Rep: 10 Posts: 6
This morning, a welder passed by and examined the hull. He believed the hull is not stainless steel, it is in fact mild steel. The gray silver color is due to stray current, that what cause the surface turn gray silver.. Is that true?... still it does not explain how the below waterline does not have any rust..
David
Old 05-15-2011, 04:38 AM
Wynand N's Avatar
Wynand N Wynand N is online now
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
David, its easy to find out if it is indeed a mild steel hull.
There are few pieces of spare stainless steel metal about 5mm left in the yacht...
and herein lies your answer. Take a piece of those off cuts and do the following;
1. If it is magnetic - 3CR12 or mild steel
2. If non magnetic, its stainless steel - note that the lower grade 302L might be very lightly magnetic. Above 308L it should be completely non magnetic.
3. Arc weld a piece with an E6013 (or E6012) and if it is problematic, burns, spatter etc and basically does not weld as smooth such as on mild steel - chances are it is stainless or 3CR12. Magnetic test will tell.
The latter can only be welded with AWS ER 309L, 308L, or 316L should be used.
IOW, if the plate is magnetic, but cannot be welded with a mild steel electrode, you most certainly have 3CR12.
Edit: Here is a spec sheet for 3CR12 - I use it all the time due to its relative low cost over stainless where marine conditions are not applicable. http://www.vrnsteel.co.za/3cr12.html
Wynand
A scatterling of Africa
Old 05-15-2011, 04:43 PM
Rep: 423 Posts: 407
David,
Do you notice any dis-similarities between the two surfaces on the scrap that you have? Regardless, if you have the chance to do as Wynand suggests, run a pass on each surface of a piece of the scrap. Note whether there is any discrepancy in weldability.
Old 05-16-2011, 04:59 AM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
A simple spark test with an angle grinder should give useful information as to material. The sparks are radically different between carbon (mild) steel and stainless steel. A couple of scraps will show this straight away.
Wynand, interesting information about 3CR12. I've got a sheet of it in the shop, am planning on making doubler plates, wear plates etc from it for my boat - all above the WL. I thought seriously of buying enough to do the entire deck & cabin as it was going to be cheaper (marginally) than the A36 plate after blasting & priming. I would have painted it as well. Chickened out as I couldn't find anyone that had done it and didn't want to be the first. Maybe next time, if there is one.
PDW
Old 05-16-2011, 04:52 PM
Rep: 423 Posts: 407
PDW
LOL, I completely forgot to suggest a spark test, most welders primarily use this method - part of basic welding program. Good thing someone had their thinking cap on!
Old 05-16-2011, 05:33 PM
Rep: 531 Posts: 489
I don't know (because I haven't done it) if there's a visible difference between say 3CR12 and 316, monel or other high nickel alloys. I'm assuming this hull isn't cupronickel because then it should look bronze-ish and it definitely wouldn't rust.
My first thought re inside rust, bright under paint outside was a carbon/stainless explosive bonded/clad steel but it's horribly expensive so why would anyone do that for a pleasure boat? Wynand's comments about 3CR12 made more sense.
PDW
Old 05-16-2011, 07:00 PM
Rep: 423 Posts: 407
PDW
I agree. I have seen/heard of a few boats with Monel cladding on mild steel. That's why I suggested running a pass on each side, just in case. But, 3CR12 would fit the bill. If the OP could post a couple of photos, int/ext, it'd be interesting to see.
  #25
Old 05-20-2011, 03:04 AM
Rep: 10 Posts: 6
According the spark test in wikipedia, it is very hard to distinguish between ferric stainless steel such as 3cr12 and mild steel...
I just began learn how to weld.. so it would be difficult for the to differentiate between the two..
I am planning cut small piece 2cm of rudder (rudder are same material as hull) and cut similar piece of known mild steel... I left them in damp condition for few weeks... see of they will be any differences in corrosion rate....
  #26
Old 05-20-2011, 03:09 PM
murdomack murdomack is offline
New Member
Rep: 267 Posts: 282
I seem to remember monel being slightly magnetic at normal ambient temperatures.
Regarding the rust on the inside surface, could this area have been ground or pollished with a carborundum disc? This can cause rust to appear on alloys.
Corrosion on stainless steel gonzo Materials 7 01-09-2011 10:33 AM
welding on a steel yacht hull Andyman Metal Boat Building 80 11-15-2010 11:45 AM
Stainless steel bottom on composite plywood hull ... kengrome Boat Design 15 09-25-2007 07:17 AM
Stainless steel properties jonathan Materials 9 03-31-2005 12:15 PM
Stainless Steel hull? trouty Boat Design 3 11-18-2002 02:57 AM
