| Spray Tack in laying in reinforcements Perhaps someone could give me a definitive answer to another question I cannot find the answer to. In infusion, when laying in the different layers of fabrics it is useful to use a tack spray adhesive to hold things in place. Some say 3M77 is OK and others say it resists the infusion like pebbles in a stream and negitively affects the epoxy cure. Is there any product out there that is recommended for infusion that actually becomes part of the epoxy during curing. I have heard that there is, but can never find a name or a supplier. Thanks Fred |
| Use Raptor composite staples, if using a foam core: They work great - and no worrying about adding questionable layers between your laminates. ![]() http://www.raptornails.com/
| Yes there is an epoxy compatible product. you can get it Composites One. NuTack® E 046-4103, 046-4106 REACTIVE TACKIFIER FOR USE WITH EPOXY RESINS IN RTM, VACUUM BAGGING AND INFUSION APPLICATIONS AEROSOL PACKAGING (Copyright 2009) DESCRIPTION: NuTack® E 046-4103 and 046-4106 are sprayable, polymeric based tackifiers. They are designed for use in RTM, VARTM or vacuum bagging processes. NuTack® E 046-4103 and 046-4106 provide enhanced positioning of coring materials and dry glass fiber or carbon fiber roll goods. NuTack® E 046-4103 and 046-4106 are based on a reactive, toughened polymer technology specifically designed for use with epoxy resins. NuTack® E 046-4103 is a neutral for color sensitive applications. NuTack® E 046-4106 contains a blue dye for visual thickness control. FEATURES AND BENEFITS: 4 Excellent adhesion to reinforcing glass fiber and carbon fiber roll goods as well as coring products 4 Maintains interlaminar strength between plies in the finished part 4 Maintains the cure and flow properties of epoxy infusion resins 4 Reactive chemistry allows broad application window 4 Neutral (NuTack® E 046-4103) available for color sensitive applications 4 Blue (NuTack® E 046-4106) available to provide visual thickness control. 4 Convenient aerosol packaging |
| I use NG-IF, which is available in spray cans and in 13,6 kg cannisters (self-propelled) and this glue does not see any problems. Also popular is hotmelt glue, as it contains no VOCs. VacTac100 is a good one. And indeed mechanical fastenings, like Raptor Composite Nails and staples, or Airtech Tackstrip. In Europe all 4 options at www.brandscomposiet.nl
| In Canada go to CCP Composites, they had been Progress Plastics until just recently. |
| Epoxy compatable tackifier Thanks to all! I contacted Progress Plastics in Toronto and ordered the NuTack E 046-4103 tackifier that "Is Compatable" with epoxy. $22.00 per can. I have searched for months but this search is over. It seems that advanced composite technical how to, is a dark art somehow. Many people will not share their information. I have not found this to be the case on this forum. Thanks again. Fred |
| spray pva on spray gel | nevilleh | Fiberglass and Composite Boat Building | 5 | 08-25-2011 01:37 AM |
| Do cats generally need a jib to tack reliably? | rayaldridge | Multihulls | 21 | 10-31-2010 07:55 PM |
| It will tack well? | sailandy | Boat Design | 9 | 03-27-2010 09:23 AM |
| Laying a hull with carbon? | 360weatherbound | Fiberglass and Composite Boat Building | 5 | 03-14-2010 01:41 AM |
| Sailrocket - Crash tack at 36 knots :-o | Capn Mud | Multihulls | 0 | 08-11-2008 10:42 PM |
