Worthless results. |
| I'm not clear whether the impact velocity listed is the one where they considered the sample broken? |
very interesting data (and very clear) for the surfboard test. Regards Richard |
| program laminate Quote: http://www.r-g.de/laminatberechnung_registrierung.html and this is a REAL test: http://download.r-g.de/rg_dokumentation_whz.pdf unfortunately (for you) in German only, and no spectra. hope I could help a bit. Regards Richard |
| Hybrid The drive to use composites has always been to reduce weight in structures. That is probably why the testing is of different thicknesses, the samples are all of a common weight (see specific gravity). The example given of monolithic materials is less typical than the use of interwoven polymers (see image). Carbon has always been champion of stiffness, Kevlar and now Spectra better in tension. The science of the interaction among the fibers is probably less understood. However, think on the scale of the fabric where none of the threads are straight, they are like sine waves. if the yield (beginning to stretch) of carbon is less than its hybrid neighbor spectra, the carbon straightens out more. The Kevlar can yield and then add its better tension strength to the matrix. Hope that helps. |
| Apex1, I'll check them out. don't understand german unfortunately. Edit: I'm unable to shift from sheet1 to the other sheets in the spreadsheet..? dccd, I don't see the correlation between specific gravity and the sample thickness in the "google book" test. I couldn't find the reference for how they made the samples. The weave thing you explained sounds reasonable. I don't know if the stuff witchcraft use is a dyneema/carbon mix or separate fabrics. For me it would be carbon uni (or rather tows) under spectra, if i can get it, I suspect these people only want to sell a 100yd roll and I only need 30yd. It is 4.1oz plain weave, 60" wide and 15.50 (us or canadian, not sure) per l.yd. if anybody is interested in chipping in. I assume none of you read the "witchcraft" description of kevlar/carbon fabric, since it is on the "customs" technical page. Quote:
Some results of a sample laminate. Attached Regards Richard |
| The third ingredient that needs to be considered here is the binder. Vinyl, poly, or epoxy resin will all add slightly different characteristics to your composite. Think of baking -- you mix a few ingredients together and they taste like the mixture that they are. Add a binder and some heat and you can get cake, cookies, or bread with only slight variables in ingredients. |
#25
But thank you anyway. Regard Richard |
#26
Apex1, you make it so I have to go back and reread all your posts... often adding a little bit of help and info afterwards... ![]() |
#27
Regards Richard |
#28
| No, not annoying |
#29
| What I wonder also is whether spectra/dyneema and also aramids have to be coated or treated to bind with epoxy. advancedcompositetraders is the correct link for the spectra I mentioned. They said it is compatible with epoxy. |
#30
http://www.dsm.com/en_US/html/hpf/products.htm http://www.swiss-composite.ch/pdf/t-dyneema.pdf Regards Richard |
| Kevlar............ | Roly | Fiberglass and Composite Boat Building | 3 | 01-27-2008 05:59 PM |
| Kevlar hull | r.mike | Sailboats | 3 | 12-07-2007 04:08 PM |
| Kevlar Guideboat | yellow cab | Boatbuilding | 7 | 10-20-2007 09:13 PM |
| Kevlar/eglass | MichaelTK | Materials | 8 | 10-13-2006 11:48 AM |
| 9 oz kevlar | Materials | 3 | 12-12-2002 04:55 PM | |
