Old 11-13-2002, 11:33 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 344 Posts: 397
SP Systems "Sprint" technology anyone?
I like what they say about it :-)
What do you say?
Erik
Sp Systems Sprint webpage
Old 11-15-2002, 01:11 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
SPRINT® - Taking the cost out of composites[quote]
just what i am looking for!
divinil aerex etc is fine material but rather expensive
another interesting sandwich at:
http://www.gammaholding.nl/parabeam/index.htm
costs i still must check.. but yes, sounds gooood!
Old 11-19-2002, 07:43 AM
ErikG's Avatar
Rep: 344 Posts: 397
Bump!
Anyone?
Old 11-19-2002, 03:57 PM
yipster's Avatar
EricG / Anyone?
i was at a bissy METS show today. got some info on AIRex and DIVINIL alternativ's THATS WHAT I LIKE HEARING
so lots of bumps today incl. SPRINT and your reply here now.
PARABEAM is not directly to make a hull with, its more like honeycomb, but with a much larger smooth surface area that also can be sandwiched, matted, some 3d also, for interior or superstrucktures etc. dont think its directly for vacuum bagging like SPRINT but for sure a different interesting sandwich!
Old 01-08-2003, 09:43 AM
yipster's Avatar
on parabeam i should ad that it comes in millimeters to centimeter(s?) thick. cost is something like $5 square meter. the sandwich stands up thanks to a capilar action to the resin and is also used for multihulls and by sunseeker for some applications i hear...
Old 01-08-2003, 03:34 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
I don't get the whole idea of Parabeam. If you fill this whole thickness with resin, you've got a really lousy fiber/resin ratio and a very heavy core. The center of a beam is heavily loaded in shear, and if the resin is applied just to the face portions of a Parabeam sandwich, I don't see how the vertically oriented fibers will resist shear. If they were crisscrossing at 45 degrees, then it might be a different story.
So my intuition says that a Parabeam reinforcement is not a very stiff or weight-conscious way to build primary structure.
Anybody got any data, one way or the other?
Tom Speer
Old 01-09-2003, 08:08 AM
yipster's Avatar
As I understood it only the hollow fibers get filled with resin by a capilair reaction leaving the space between open and filled with air like a honeycomb. How? Air inside a laminate (as with a honeycomb) is reason for not carrying a full certification by the industry for boat hulls?
Came close to trying it out and I should have. It’s a tricky concept and even with air inside I’ve been wondering about the (light)weight. It is used also as sandwich panels in truck floors etc. so it must be strong. The thicker quality’s I was informing for indeed would be better of with a 45 degree weave I agree.
contact Jurgen Koot jkoot@parabeam.nl at http://www.gammaholding.nl/parabeam/index.htm i found him a proffesional and more than pleasant man to talk with, and I am sure he can clarify these questions as I still have also. i asked him some more info. Its innovative but how well suited for multihull building -as he mentiont was done- I don’t know.
New Fixed fire suppression systems Jbrooks Press Releases 1 06-22-2005 10:56 PM
New Fixed Fire Fuppression Systems Jbrooks Powerboats 3 06-15-2005 08:35 PM
New Fixed Fire Supression Systems NFPA 2010 Jbrooks Marketplace 0 06-14-2005 03:25 PM
Yachtica Integrated Systems yachtica Materials 0 03-28-2002 07:34 AM
