Old 10-13-2009, 08:32 PM
Carolina Flare Carolina Flare is offline
Rep: 10 Posts: 12
Source for Core-Cell
Hello All
This is my first post and by the looks of things I will be able to get all the info I need.
My question is sources for Core-Cell bead and cove here in the USA.
Thanks for your help
Steve
Old 10-13-2009, 08:45 PM
pamarine pamarine is offline
Marine Electrician
Rep: 70 Posts: 147
Originally Posted by Carolina Flare View Post
Hello All
Steve
If you find it let me know. We have to get it from Canada or take sheet-stock and make it ourselves.
Old 10-13-2009, 09:03 PM
Rep: 10 Posts: 12
Thanks replying.
I will.
I talked to jack at Jamestown supply and he is going to check it out but he has not called me back.
A person could make it himself just need to router bits and router with a speed control.
Thanks
Steve
Old 10-13-2009, 11:40 PM
Marine Electrician
Rep: 70 Posts: 147
Yea, right now when we need small runs we make it in the shop out of our sheet stock. But when we are preparing to lay-up a new hull we order it pre-made.
Old 10-13-2009, 11:50 PM
Rep: 10 Posts: 12
Will you tell me where in Canada?
Old 10-14-2009, 01:14 AM
Marine Electrician
Rep: 70 Posts: 147
I'll have to double check, But I think we are getting it ATC in Ontario
Old 10-14-2009, 07:12 AM
Bentwood Bentwood is offline
Bentwood
Rep: 10 Posts: 21
The best source of core cell was composites one, but they only supply by the case. I think you will have to strip the panels and bead/cove them yourself. The layup may be easier if you consider wider panels running from sheer to keel rather than narrower strips running fore and aft.
Old 10-14-2009, 08:40 PM
Rep: 10 Posts: 12
I will need a case and hope it will be enough. It will be very close to being a few short. I'm going to strip plank the sides because it will will be very curvy. I thought about using Durakore strips but I like the thoughts being synthetic.
A pro builder on nc coast is helping me and he has used many different materials.
The bead and cove seems to me to be the best product. The bead and coves kinda loosely lock together. I will use sheets for decks and the bottom and transom.
Thanks Steve
Old 10-14-2009, 08:47 PM
Marine Electrician
Rep: 70 Posts: 147
The bead and cove is great, we do the same thing just up the coast from you on our boats.
Old 10-15-2009, 01:12 AM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
Try Noah's. I thought I saw some on their site.
Old 10-15-2009, 08:53 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
If you start working with the bead and cove system, make sure you read this book as well:
http://www.cyberstreet.com/andre/
If you want to order, make sure you call him first. I lost track of Andre long time ago, and I am not sure if he is still around.
The bead and cove can very quickly be made, if you have the right equipment. (tabel saw, router table with tractor). I produce B&C in the Netherlands, not much of interest for you guys, I am afraid.
Old 10-16-2009, 07:51 PM
Marine Electrician
Rep: 70 Posts: 147
Ok, talked to the Bossman and we are getting it by the case from ATC Chemical in Ontario. We are actually ordering it through our local composites distributor though. So depending on where in the OBX you are they may be fairly local
It's Eastern Burlap in norfolk, VA
Double "strip planking" Core-Cell SeaJay Materials 13 10-18-2009 07:06 AM
core-cell for deck Bentwood Fiberglass and Composite Boat Building 2 05-13-2008 12:29 PM
PU foam VS Core-Cell or other? Danielsan Fiberglass and Composite Boat Building 18 07-17-2006 08:42 PM
core-cell deck fabrication dolsen Boat Design 2 06-20-2006 07:50 AM
Core cell or Balsa?? SOB Fiberglass and Composite Boat Building 5 01-10-2005 01:51 PM
