Old 03-21-2004, 05:34 AM
coach coach is offline
Rep: 10 Posts: 4
small gelcoat repair
I have been doing small repairs with a prevalve sprayer and using patchaid to thin the gelcoat. Problem is it's either to thick to spray or if I thin it more It runs and I end up sanding through the patch because of not enough build up. Anyone have any advice. Thanks
Old 03-25-2004, 09:12 AM
Saltyredfisher Saltyredfisher is offline
Rep: 10 Posts: 17
Have you tried using acetone to thin the gel. You can pick up a small cheap self contained spray can at Home Depot for $3.00 or so. Get rid of the bottle that comes with it and use 2 ounce nonwax paper cups. You can get better angles with that. This has worked for me many of times. Good luck!
Old 03-25-2004, 12:12 PM
Rep: 10 Posts: 4
Yes, when the patchaid did not thin it enough I useed some acetone but have still had problems with it being to thin and sanding through after. I am wondering if the pre valve is just not good enough to spray gelcoat patches.
Old 03-30-2004, 06:13 AM
Rep: 10 Posts: 17
Use that sprayer I was talking about. Take some time spraying it. Wait a little bit between coats. And the sanding through sounds like to thin ,but also to aggressive of sand paper. What grit are you using? I mostly start off with 320 just to knock it down quick then 400, 600, and 800.
Old 03-30-2004, 05:33 PM
Rep: 10 Posts: 4
gelcoat
Yes I was using 320 sandpaper to knock it down. I will try one of the sprayers you are talking about. Could you tell me what brand it is. Thanks Coach
Old 04-02-2004, 06:22 AM
Rep: 10 Posts: 4
Went to home depot they said they dont have sprayers. Could someone tell me what kind of sprayer they would recommend to do gelcoat repairs. Thanks
Old 05-25-2004, 12:49 PM
keith joiner keith joiner is offline
Gel Coat Sprayers...
You can usually get a sprayer from craft stores. They use a can of compressed air.
Old 06-09-2004, 10:26 PM
jwilliamson jwilliamson is offline
gelcoat sprayer
instead of acetone to thin gelcoat for spraying, use a product called "Duratec" which makes gelcoat more like paint. The disposable gelcoat sprayer (sold by Home Depot or some paint stores) is called "Preval"
Old 06-26-2004, 09:54 PM
JWP54@att.net JWP54@att.net is offline
I have a terry bass boat with a 115 evinrude and I want to put a 9.9 beside it but I only have about 5inches on each side of the motor. Does anyone have any suggestions on how to mout this 9.9?
Old 11-18-2004, 10:33 PM
R.D. R.D. is offline
I Use Duratec 1:1 Mixture To Spray Gel Coat
Hello There...
Duratec Gelcoat Thinner (rev-chem Plastics Is The Company)works The Best For Thinning Down Gel Coat, Put A End To The Accetone..its Great Because Its Easy To Use With No Guess Work 1 Part Duratec To 1 Part Gelcoat..it Is Also An High Gloss Additive As Well As Curing Promoter...
Hope This Helps..when Building Molds It What I Use..:d
R.d.
Old 11-27-2004, 07:09 PM
guyan guyan is offline
Rep: 10 Posts: 4
gel coat for metal???
new on line so excuse me.
i need to talk to someone about gel coat for a gas tank for a motorcycle.
i'm trying to see if this wonderful look can be achieved on metal??
want the old 50's looking metallic look with the huge fishscale look??
thanks.
Training for Fiberglass and Gelcoat Repair jbrown15 Education 3 02-07-2011 05:09 PM
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
Gelcoat project on 71 Shark LtsGo4ARide Fiberglass and Composite Boat Building 4 07-03-2005 11:02 AM
Gelcoat Ring repair rianhanson Fiberglass and Composite Boat Building 0 04-29-2005 11:23 AM
gelcoat repair glassr Fiberglass and Composite Boat Building 3 02-24-2005 07:53 AM
