| Should I dry out my transoms plywood core before closing? I cut the top of my transom off to lower it about a month or two ago. It is in an unconditioned garage in Houston, TX. Will the plywood absorb moisture to the point that I should dry it out before closing it back up? Kevin |
| If the core is exposed to open air it might make some absorption,but it depends how much bad the condition is ofcourse?generally as i know when the humidity exceeds 12% the problem starts.
__________________ Tumer Berk |
| Humidity is way over 12% here, how should I dry it out? Kevin |
| Since your transom top is all that has been removed and it has been under shelter, the moisture content will be quite stable. Put the transom top back on with no worries. This assumes you don't have other issues with your transom, like engine mount holes that let in water or other fastener holes that do the same and that the transom is solid. |
| There is a handy chart in the back of the Geougon Bros. Book on boat building that shows moister content for different wood at certain humidity levels. It also has the average humidity levels for areas of the US. You should not have a problem keeping it at or under 12% if its covered – especially this time of year
__________________ www.boatbuildercentral.com |
| wet and dry sanding | bojangles | Fiberglass and Composite Boat Building | 9 | 04-07-2006 02:15 PM |
| Transoms-fiberglass powerboats | tonyg1178 | Fiberglass and Composite Boat Building | 4 | 09-17-2005 04:22 PM |
| Transoms | andrew | Fiberglass and Composite Boat Building | 4 | 11-02-2004 03:30 AM |
| closing up inboard holes | eurotk1 | Materials | 1 | 05-12-2004 11:12 AM |
| Dry exhaust vented through mast | mmd | Boat Design | 5 | 09-07-2003 06:35 AM |
