Old 12-17-2006, 05:55 AM
avogelnik avogelnik is offline
Rep: 10 Posts: 7
sheathed with epoxy - building the boat rightside up
Hello,
I am building the 43´ wooden schooner. There is idea building the hull to the chine with plywood.
Does anybody have experience have is sheathed with fiberglass and epoxy if your boat is rightside up.
lp avogelnik
Old 12-17-2006, 08:37 AM
BTScow BTScow is offline
Rep: 10 Posts: 42
It is a little tricky, but with a second set of hands it shouldn't be too bad. There is no doubt if you could flip the boat over it would be easier, but I understand the reservation about rolling a 43 foot boat.
Crayke
Old 12-23-2006, 10:13 PM
Rep: 1397 Posts: 7,216
I've done that many times to sheat older boats. Set up a work table on the side of the boat. It has to be as long as the boat. Lay plastic sheeting over it. Put the fiberglass cloth over it and soak it with epoxy. Roll it on a piece of plastic pipe. One person holds the roll and walks it, while two lay the fiberglass over the wet epoxied hull and take the excess resin and air bubbles with a squeegee.
Old 01-08-2007, 01:50 PM
Rep: 10 Posts: 7
Thanks.
Compatibility......foam core & sheathed edge glued Roly Fiberglass and Composite Boat Building 1 10-25-2006 02:03 PM
epoxy primer sprayed on green epoxy laminate? bntii Boatbuilding 12 10-16-2006 07:41 AM
Sheathed strip - Limits? Mohan Pakkurti Wooden Boat Building and Restoration 1 01-24-2005 11:01 AM
Designing a wood epoxy classical boat. Sailboats 13 03-21-2003 06:42 AM
carbon-epoxy mast building krobas Boatbuilding 0 11-08-2002 05:25 AM
