Here are the pictures I promised and a few other notes:
Here is a shot of the transom once the motor was removed.
You can see all the holes in the transom, some had been sealed, some had not.
Here is a close-up of where the engine was literally sinking INTO the rotten transom
Seacast says use a chain saw, so I touched it to the top of the transom. Sunk right in.
Using the chain saw really was as easy as Seacast said it would be. The rotten wood came out just like mulch. Notice the soft brown shreds all around. Because the wood was soft, it was easy to shave right up against the glass. I finished the wood removal with a chisel mounted to a piece of 1x2 maple, and then used a shop vac with a piece of 3/4" hose on it to get everything clean as a whistle inside.
Then I used a grinder and glass tape to close the holes, damaged areas and giant scuppers. Then I poured the Seacast. (sorry, no pics- I had my hands full, and I didn’t want to mess anything up)
Pouring the Seacast was almost a non-event. You mix it up as directed, and pour it in. I used a stick to push it around and then thumped it with a rubber mallet to release any trapped air bubbles. I laid a piece of glass tape across the top, and three hours later, I had a VERY solid transom! I couldn’t be happier!
The patch work I did to the skin of the transom needed to be cleaned up, so I mixed powdered glass into some resin and skimmed it flat. Very easy, if you’ve ever done any drywall work. Sand it and do it again, and she was ready for spraying gel coat:
Here is a picture of the transom after spraying. Sorry about the haze, the camera had been in A/C, and I grabbed it for the pic, and it was 100 degrees outside, hence the condensation.
And that’s pretty much it. Seacast really lived up to it’s claims. I already knew this from others on this board, but I’m glad it proved true for me, too. I'm confident that this transom is stronger that it has ever been before, including when it was brand new.
In summary... It took me 5-6 hours to get the transom cleaned out over several afternoons, less than 1 hour to tape the holes shut, 1 hour to pour the Seacast, about 4 hours over a couple of days to skim out the repairs and about 3 hours to spray the gel coat. I will buff and wax the new gel coat, (about 2 hours) and put the motor back on. (about 1 hour)
So the total investment for replacing my rotten transom is $497 in materials and 17-18 hours of my time in the evenings. It would have been a LOT LESS, had the damage to the fiberglass not occurred, probably more like 10 hours.
Hopefully, I’ll finally be back on the water by next week.
-TH
-TH
