Old 02-12-2005, 02:26 PM
SeagullVolusia SeagullVolusia is offline
Rep: 13 Posts: 2
In Response...
What is the major difference between today's composite hulls made of the 1/4" fiberglass, foam material, 1/4" fiberglass construction and a full solid material like Seacast® :
• The difference is that Seacast® is based on the same material as the rest of the boat a the hull. Seacast® has a certain amount of resiliency, which keeps it from cracking. In seventeen years we have never had a cracked or broken transom. Even with the enormous Hp hung on some transoms.
•*In contrast to foam, Seacast® is not friable - so the bond is superior. Seacast® has been tested by a dropping 20 lb weight, from a height of 10 ft, on a 6" wide 1.5” thick piece of transom - did not break after 200 repeats. In comparison, a standard plywood transom is destroyed after one drop and all other materials tested failed after the third drop.
• As to the question of bonding to wood. Yes, it bonds very well, BUT you must remember the wood itself will be the “weak link”.
Flexural Test Results
• Structural Composites, Inc. tested Seacast® against marine plywood.
Panels Flex Strength Flex Modulus Max Load Catalyst
Seacast® A 17290 psi 903762 psi 6053 lb MEKP
laminate
Seacast® B 17641 psi 845039 psi 6443 lb BPO
laminate
21 Ply hardwood 10204 psi 1005342 psi 3598 lb
All other tests results will be on our new website soon.
Seacast: The Bottom Line-fiveengine.jpg
Old 02-16-2005, 08:57 AM
tdmuir tdmuir is offline
Rep: 10 Posts: 2
Seacast Made a Believer ( So Far )
Guys, I don't know what all of the fuss with seacast is about. I called and talked to a representative at Seagull of Volusia on February 10th to request some written information and a sample of their seacast product. I recieved the seacast sample and the step by step guidelines for its use on February 15th. That is only 3 working days. I find that to be excellent customer service. The product sample that I recieved was a small piece measuring 1.5" thick and approximately 3" in width by 1/2" in thickness. From what I can see this seacast is very strong and adherses very well to "Fiberglass". With reading all of the information sheet and the website it clearly states that seacast is a filler compound to be sandwiched between fiberglass barriers. I'm a firm believer in the product now that I've actually had it in my hands. Seagull of Volusia, I say to you that I will be using the product in the very near future to pour a transom. If that goes off without a hitch then I do plan on using it to redo the stringers in the boat as well. Thanks again to Seagull for their wonderful customer service. You all obviously believe in your product.
Old 03-02-2005, 10:27 AM
bill11 bill11 is offline
Seacast
undefinedundefinedundefined
I have run a boatyard that has used the seacast to repair rotted stringers in a powerboat. I was not at all impressed with the application or the results. After "pouring" 4 stringers and letting them cure I was not satisfied with the results. There was an excessive amount of time prepping the existing skins in order for the seacast to properly adhear to the skins.The resulting "stringers" did not exhibit nearly the strength or rigidity I needed. I ended up replacing the stringers with wood glassed over.
Old 03-04-2005, 10:22 PM
steigermike steigermike is offline
Rep: 10 Posts: 7
par is right on with this, there is no way around doing it the right way and briefly that is to remove the rotted core from the inside leaving the outer skin and going with a synthetic or marine ply as your core material and using a traditional layup method with west system epoxy.
Old 05-12-2006, 09:45 AM
jahale jahale is offline
Seacast
Three years ago I was given an old Mark Twain. I gutted and redid the interior, and on the third weekend out the transom split. It was rotten. I looked at my options, trash a boat I just refurnished, spend 1500 on a transom repair, or try something else. I chose Seacast. Granted it took time to chainsaw out the old transom completely, but with prep, shipping, and curring, the process took me very little time on the whole, much less than replacing the transom the other way. The Seacast was easy to pour, and the transom came out perfect, in fact, much stronger than the original ever was. That was three years ago, and it has been tested many times since. Total Cost $350. I will recommend and support Seacast as long as its around. The product saved me soo much time, work, and money. I don't know about using it for floors or anything else, but it is the best for transoms.
Old 08-31-2009, 07:34 PM
foca foca is offline
Rep: 13 Posts: 12
UPDATE!!!!!
I made Seagull's month. I spent over $1500 on the stuff. what i did was not possible with any other (sane) rebuilding method. Main stringers all the way forward and transom are now FULLY COMPOSITE... no more balsa. all this without touching my deck and working only through access hatches. all my original gellcoat remained!! why rebuild with an inferior product when you can make it last forever... hmmmm... ok maybe just longer. if you can take the extra 200 lb penalty... seacast and epoxy all the way dudes!
THEN, i hung a 30" bracket and twin V6 HPDI's on the back. I've been pounding the boat for 3 years... zero signs of stress fatigue so far. Looks like it came like this from the factory.
screw west systems, call up mark at US composites and tell him to set you up with the his thin epoxy and some combo 45 deg mat.
WOOD SUCKS!
Old 09-01-2009, 06:08 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Originally Posted by foca View Post
UPDATE!!!!!
WOOD SUCKS!
What you mean is BALSA sucks.
Quite a lot of discussion on that around these forums.
Old 09-02-2009, 03:02 AM
PAR PAR is online now
Rep: 2891 Posts: 8,796
Foca, what you did was pour a liquid polyester, into dirty and contaminated stringer cavities. Polyester requires a mechanical bond in this application, which you can't get without exposing the previous core areas and grinding them with a very aggressive grit.
In short, you now have stringer tubes full of a material that doesn't offer longitudinal strength, but most importantly isn't well bonded with the laminate. For a cored structure to work as intended, the core and the laminate have to be well bonded. If they aren't the core will shear from the laminate and the two will act independently of each other, which isn't good.
I hope you have good luck with your choices, but I've repaired enough stringers and transoms to know for sure, that there's no miracle goo in a can going to save the day.
Old 09-02-2009, 11:18 AM
Rep: 13 Posts: 12
hmmm, NO, i mean ALL WOOD sucks. my transom wasn't balsa, and most aren't. They rot too.
i work for a company that makes helicopters. One of our helicopters has wood in it... it was designed in 1950.
today, entire production aircraft are composite... like it's always been in the past, aerospace technology eventually works it's way down to other industries.
the only reason only SOME manufacturers have switched to NO-WOOD construction is simple: COST.
composites take more knowledge, design work, technical skill, and of course cost more in material. They have come a long way in the last couple decades. wood is outdated. period. If you want to cut cost and you can totally encapsulate it (not a SINGLE hole through the glass), then it is merely ACCEPTABLE.
this is starting to sound like the old carbeurated vs EFI discussion, those guys thought old technology was better too back then, but there is not too many of those dudes left today. yeah, columbus did the atlantic in a wood boat. means nothing now, it's time to move on.
it's been done... it only takes money. intrepid has had wood-free models since the early 80's... they're still not rotten.
  #25
Old 09-02-2009, 11:36 AM
Rep: 13 Posts: 12
PAR,
there is a SOLID mechanical bond. it was scratched and cleaned COMPLETELY before the pour. Before doing anything i took samples of the existing glass and did bench tests for bonding to be sure. trust me, it is more solid than if i was trying to bond to wood. if you did a tensile strength test, you'd have to pull harder to get the glass off of the seacast.
since we are talking shear though, I have seen no evidence of problems YET. not through bench testing and not in the boat application. I took the tank lid off and inspected the two main stringers a couple months ago, no signs of delamination.
Bear in mind however, this boat was also structurally enforced with Epoxy layups after all the poly work was completed. there are more loads now with the bracket and twins, but the load paths have been looked at and reinforced (that may be better OR worse for the seacast bond... we'll see).
SO FAR, i have complete confidence. Tried and true is great, but it didn't get us to the moon. If we have better tools today, why not use them. I think the risk is minimal at this point, as long as you are smart about it.
  #26
Old 09-02-2009, 01:00 PM
mark775
Two of the testimonials look fishy. Foca, you just have no idea of what you are talking. Good luck with your "flexible flyer"!
  #27
Old 09-02-2009, 05:47 PM
Rep: 13 Posts: 12
Attachment 34596
"fishy"...OK.
good luck with your rotten (or rotting) boat(s).
Developed Surfaces???? ChrisGibbs Boat Design 49 03-24-2006 09:38 AM
Rhino and Bottom longs 3dig Software 2 05-08-2005 11:33 AM
Need help on designing stepped forward-vented bottom hulls with staggered strakes Trimix Boat Design 0 09-15-2004 01:15 PM
Viewpoint names in Rhino Willallison Software 14 03-02-2003 10:55 PM
