Old 04-09-2011, 07:02 PM
slow fred slow fred is offline
Rep: 47 Posts: 25
Sell all of the aluminum and buy 5/8" exterior plywood. Put 2 coats of exterior house paint on it before you install it. Put on some carpet, and it will last 10 years. This is not rocket science.
Old 04-12-2011, 09:08 PM
Pstoney Pstoney is offline
Rep: 10 Posts: 9
Thank you all for all of your help and expertise!! Just to let you know, I stayed away from the wood, and added T-6 6061 aluminum U Channels every 7" with stainless steel fasteners!! Thanks again!!
Old 04-12-2011, 09:25 PM
Rep: 10 Posts: 9
I know its not rocket science, but I wanted to get away from wood period, because I dont want to have to replace the floor again in 10 years. And that is exactly what I did with all the great help from here!
Old 04-13-2011, 08:28 AM
Rep: 3125 Posts: 9,399
The "U" channel is exactly the way I would do it. It stiffens up the sole plating, keeps the weight down, but more importantly, permits moisture to naturally drain off (assuming the U is facing down), so corrosion is reduced. Okay, now post some photos, so that others looking to do the same thing will have a clue . . .
Old 04-13-2011, 07:19 PM
Rep: 10 Posts: 9
Thanks, I will!
Installing Floor in Aluminum Boat Fishing4Life Boat Design 3 06-02-2010 08:10 PM
Floor Replacement For Aluminum Boat jimquik Boatbuilding 2 08-01-2008 11:48 PM
Newby replacing aluminum boat's floor Brylk1830 Materials 12 05-27-2008 09:28 PM
aluminum cans on the ocean floor sjo hest Metal Boat Building 52 09-08-2007 03:50 PM
Replacing Floor on 17' Aluminum runabout NanookofNJ Materials 10 04-23-2007 04:02 PM
