| Runabout engine cover building an 87 vindicator. to the point of building the engine bay cover and rear seat. I didnt' like the old closed up crowded style and 3 part cover so I"m looking at building a frame out of tubing and incorporating the back of the seat. I wanted to used aluminum but I'm having a hard time finding anyone out here in lubbock that can weld it. should I keep hunting or should I give up and use light gauge steel? and have it powdercoated. |
| what about stainless steel? |
| still the same problem of getting someone to tig weld it |
| You can weld stainless with MIG. It only takes a different wire alloy.
__________________ Gonzo |
| If I go the stainless route, how much of an issue am I going to have with coorosion if I skin the underside with aluminum? |
| Put tape in between to avoid corrosion.
| insulating deck cover | Specmar.Aus | Metal Boat Building | 9 | 02-08-2006 01:39 PM |
| How to make snowmobile engine work in a small 11 ft. runabout? | rvBilly | Propulsion | 8 | 09-02-2005 10:49 PM |
| Bike engine in small runabout | Danielsan | DIY Marinizing | 8 | 06-12-2005 09:19 PM |
| cover for bayliner 175 | auskins | Powerboats | 1 | 08-30-2004 01:31 PM |
| stiffness question for engine cover | hot for teacher | Boatbuilding | 14 | 10-28-2003 05:33 PM |
