Old 01-27-2005, 02:08 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
Rudder Bearing
Next to my workplace, in small town called Virginia here in South Africa, is a big factory called Vesco. They manifacture a bearing material called Vesconite. As we do a lot of work for them, I pop in there often.
You should see the massive rudder bearings made from Vesconite for big ships destined all over the world.
This brings me the question, have anyone any experience with Vesconite, are there better materials for rudder bearings?
Interesting, all the Vesconite worldwide departs from this factory. Quite amazing to see the manufacturing process.
Wynand
A scatterling of Africa
Old 01-27-2005, 04:41 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
The name sounds familiar, but to be frank, I haven't been able to make the connection. Do they have a site to look at?
Wanneer vertrek je?
Old 01-27-2005, 10:52 PM
Wynand N's Avatar
Hi Brien,
Here are their website and anothers.
http://www.vesconite.com/
http://www.vesco.com.au/vescoplastics.html
http://news.thomasnet.com/fullstory/22405/1620
Sal vanaand 'n privaat e-pos stuur met besonderhede.
Wynand
Old 01-28-2005, 07:59 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
Thanks Wynand N for that interesting info.Have been looking for other water lube bearing material.If it is as good as my present material or better it sure is great stuff.
The material just hardly polishes a stainless steel shaft.
tomkane
Old 01-30-2005, 10:53 AM
nassaw nassaw is offline
Rep: 10 Posts: 36
Seems as though Vesconite is becoming a standard bearing quoted to be used by several designers on home built projects. I know Chris of Chris White Catamarans is requiring them with his designs. I opted for a different material that is also used mostly in my area because its produced here locally in my home town. (UHWMPE) I did several test before deciding to use. 1st I submerged a piece in a saltwater tank for 2 years. With a humidistat I found no change. I also found no biological growth on the sample. I also did shop bench test and turned a shaft in the bearing 1 million revolutions and reversed the motor for 1 million revs. I then forced the bearing hard over in the jig and 1 more million rev. and tried to eggshape but the sample stayed true and unchanged. Sent the pieces over to a machine shop and rebored to my actuall SS rudder stocks. Not sure what the cost of this material cause I traded a case of beer for a box full I can check if anybody is interested.
Wynand, What is the price for bearing. say for a 2"(51mm) shaft. Here is the site for the UHWMPE.http://www.garlandmfg.com/plastics/products.html
Old 01-30-2005, 03:29 PM
tom kane's Avatar
Rep: 265 Posts: 865
Some of these materials seem to aquire different trade names in different countries.I have a list somewhere?..NOVASTEEN is one name given to a similar product.
tomkane
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Rudder Design and Broaching joebobb Boat Design 0 02-25-2005 10:43 PM
Powerboat rudder design brooksie43 Boat Design 17 01-18-2005 09:52 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 04:36 PM
Rudder bearing service kudu Boat Design 2 06-27-2003 12:14 PM
