Old 05-10-2009, 08:38 AM
longfellow longfellow is offline
Rep: 17 Posts: 35
Roofing material for bedding?
I'd like to try traditional reinforced roofing tar to bed keel and stem components. Are there any particular types or brands that are better or worse than others? I have something in my shop from a previous home repair that I believe has some form of reinforcing fibers mixed in which I'd like to use. Mineral spirits clean up is an added benefit.
Thanks.
Old 05-10-2009, 11:46 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
I recall using an aluminum-based fiber reinforced mixture to patch a trailer roof, but I wouldn't trust anything with aluminum in it near salt water. Is your mixture silver?
The fibers--- do they list the ingredients?
Old 05-10-2009, 12:03 PM
BLACKIE BLACKIE is offline
Rep: 10 Posts: 8
roofing tar is somewhat watersoluble.
it also shrinks as it dries. fibers or not.
speaking from experience.
Old 05-10-2009, 01:14 PM
alan white's Avatar
Water soluble? To some degree that is actually noticable or matters? Is this something that's generally known? I know it dries out. But whereas my asphalt roof is close to 25 years old and still okay, I am imagining tar in a crevice not subject to the sun at all. Melting away?
Old 05-10-2009, 03:28 PM
Rep: 3125 Posts: 9,399
There are a few basic types of roofing tar or cement used. You want the petroleum based stuff, not the polymers. Yes, some shrinkage is to be expected, particularly if exposed to UV. The polymer based stuff may very well be slightly water soluble, but I'm fairly sure the petroleum isn't.
Be warned, this stuff gets all over everything, regardless of how careful your are. You will have a very difficult time painting over it and it will always smell like, well, tar.
Old 05-10-2009, 03:42 PM
alan white's Avatar
Sounds like roofing tar, if petroleum=based, would do best out of sight and under water, say as a bedding compound for deadwood, floors, ballast-to-keel faces, plank lands (below waterline), centerboard trunks (logs and faying against bottom). What do you think, PAR?
Old 05-10-2009, 05:07 PM
Rep: 10 Posts: 8
i've used tar in the past on wood boats. i really wanted it to be a good thing. but i won't use it again if i have other choices.
some reasons--
it's not springy, so bedding with it just squeezes it out, then when it shrinks it leaves pathways through the bedding. it can't well be painted over. if i were un-experiencd, i'd still be trying it out, because i love the idea of it-- so old school etc., cheap, mineral spirit compatible-- all the reasons that led me to try it out for years.
now my favorite cheap stuff is Alex Plus 50 yr latex caulk. Even the 35 yr stuff. Home Depot chandleries. It sticks, has body after drying. Elastic as all get out. Cheap. Water clean up. I used it for 6-8 years on an old wood boat. 2 atlantic circles. 5 years in west africa. Another good thing about it is when it's time to repaint, it can be added to, or removed easily-- it's not overkill-tough, like 5200.
above water only or course.
Old 05-10-2009, 07:20 PM
Petroleum based tar was and in many parts of the world still is the preferred bedding compound for deadwood assemblies, under strut flanges, between diagonal plank layers, etc. It can be painted, but because it never really gets hard it will crack and split the paint film with any movement or contact. It's more effective then Dolfinite, but used in a similar fashion and has similar qualities.
I wouldn't call Home Depot or any other home improvement store a chandlery, nor would I use bath room type caulk on any wooden boat. Metal or GRP are better choices for this low grade type of caulk, but not on my boat, it just doesn't hold up to the tropical sun.
Blackie, there's a fair bit of difference between bedding compounds, sealants and adhesive/sealants. Often one can't be used in place of the other. Given the number of choices and durability of the selection now available, it seems fruitless to be frugal in this regard.
Old 05-10-2009, 09:45 PM
Rep: 10 Posts: 8
beg to differ, par. holds up splendidly under the african sun, as i pointed out. these are just chemical compouds, my friend, not gifts from the nautical gods.
tar has been used traditionally mostly because it was available. meaning home depot hadn't arrived yet.
Old 05-10-2009, 10:28 PM
Rep: 10 Posts: 8
and don't get me wrong. tar has a lot of uses on wooden boats. toilet seal wax is also useful. no ****. that's funny. but i mean it.
bear in mind that "tar" refers to a miriad of substances, with a very broad range of characteristics. fibered black-jack, fer instance is way different than the hot-pitch on your roof, alan.
and yes, black-jack is fine in any third-world type approach to building, which is necessarily frugal, par. i've used a ton of it. but it's downside (messiness, paint bleed-through, and shrinkage) was, for me, finally not worth it, except for emergency patching and the ilk.
it's good for sealing the wood after digging out rot prepartory to filling the void with cement when you can get away with it structurally. (drive a forest of little nails half-way home after the tarring, for the concrete plug to anchor by)
Old 05-10-2009, 11:16 PM
Okay, I guess all us engineers, builders and designers with countless decades of experience must be wrong and lowly old bath room caulk is the answer. Damn how'd I miss that. Frankly, I've tested most of the major brands and formulations and my tests coincide with manufacture and independent studies as well, but hell who are we . . . or possibly more importantly, who are you?
Old 05-11-2009, 07:46 AM
Rep: 17 Posts: 35
Well, I used it and we'll see how it holds up. I am using this first wooden boat as a sort of test bed for materials as well as construction techniques; being careful to only take on acceptable risks so that my boat still gives me a fair number of years of enjoyment.
So I used a petroleum based asphalt material, but I went with one that has no fiber thickeners - though I did see "clay" in the "contains..." section of the tube. It went on yesterday, between my new cutwater and the stem so it is partially below WL. Since it cleans up with mineral spirits and is a great consistency as far as bedding goes (at least on the cool day that I used it), it made for a very clean looking final assembly with a faint line made by the fillet showing. My hull is Brightside deep blue so it is barely noticable. I am not going to be able to put in the water until after the Mystic show (she is participating in the "I built it myself" display this year.) but I am sure she'll be fine. Thanks all for the useful input.
Old 05-11-2009, 08:47 AM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 576 Posts: 1,066
fwiw, i have to use an approved sealer, sika, or other for any customer for obvious reasons, however if its for your own boat , i think you should look at the expansion jointing compound used between concrete blocks in sea defence walls, it must be tough stuff, & a lot cheaper
Old 05-11-2009, 12:19 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
Ive used my share of Sika and its vastly superior to tar
I hated using tar and waaaaaaay back in the day pretty much stuck to pine tar ( har har har ) rather than petroleum tar as a bedding for pins and such. It got everywhere and at the end of the day you always ended up smelling like a pine tree.
Sika also gets everywhere and also cleans up with alcohol has significantly better stick and is highly paintable
costs a fortune as well
B
Old 05-16-2009, 01:11 AM
Rep: 418 Posts: 777
Well I think weather and style of boat have a lot to do with it. We did some remarkable repair work with roofing tar on old worn fishing boats in Alaska. On the right vessel tar smells kind of good. It didn't get very hot up there and I think that helps a lot.
Another great product for cooler weather is cosmoline. There were lots of ex military guys around and several people had big buckets of the stuff. Painting hydraulic motors and fitting with this stuff and then wrapping it with this waxy tape product made a messy but bullet proof covering. You would cut it away and find a gleaming motor or fitting underneath. Pretty sweet for gear living on deck and subject to saltwater washdowns every day. With practice we developed a method of wrapping the waxy tape with some sort of cloth tape for several layers and then painting it with porch enamal mixed with a little jap drier. You didn't want to sit on it but it really wasn't too bad and when the underlying parts had to be serviced it made you grin a little bit. Not really yacht grade but effective.
Bedding Compound? flydog Boat Design 7 05-15-2010 07:36 PM
Bedding stringers? mstuhr Fiberglass and Composite Boat Building 13 05-29-2006 10:04 PM
Bedding Stringers man5 Fiberglass and Composite Boat Building 2 04-14-2006 06:35 PM
Bedding Fasteners boatrat Wooden Boat Building and Restoration 3 04-12-2005 10:51 PM
Bedding Aluminum? GrapeNutsCereal Boatbuilding 1 07-24-2004 10:19 PM
