Old 12-22-2007, 06:33 PM
grp.boat grp.boat is offline
Rep: 10 Posts: 46
Rib Tube Material
I am trying to find a distributor for the pvc or pu fabric used in manufacturing rib (rhib) tubes. Can anyone help???
Old 01-27-2008, 09:56 AM
Anchor Dan Anchor Dan is offline
Rep: 10 Posts: 3
You Bet ! I've made air ribs for years. and they work great, weight down and conform to the hull shape.
Go to a local supply store and get clear flexable tubing, like for water, size and length you need.
Put a plug on one end (brass?), clamp it with a radiator hose clamp and on the other end do the same, BUT drill a hole , tap and install a tire air fitting in the plug, clamp it. Then charge it with 30 to 40 # of air pressure. wax it and or pva. The air willexpand the tubing.
Give it a baseball bat rap with glass and resin, lay it in the hull, glass it in and let it kick. The next day, I let the air out,it shrinks in size, take one end cap off and pull it out. On to the next one. I call it and air ribb, because there is nothing but AIR left ! Good luck !
Old 01-27-2008, 11:08 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
http://www.frg.com.tw/p-boat.htm
They have a lot of fabrics etc to other purposes aswell.
RIB hull design and tube attachment jamesdedward Wooden Boat Building and Restoration 13 09-10-2011 03:22 AM
RIB tube/collar life? Nojjan Materials 2 08-08-2007 03:33 AM
RIB Tube maker Jeff Therrell Fiberglass and Composite Boat Building 16 04-13-2006 06:09 PM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
aluminum tube eurotk1 Metal Boat Building 2 12-27-2004 09:47 PM
