| rib hull I am looking at building 9mtr ribs and am after some assistance on the layup. I was going to lay it up as follows. Gelcoat 300 g csm 300 g csm 600 g woven roving 300 g csm 300 g csm 600 g woven roving 300 g csm 300 g csm 600 g woven roving 300 g csm and then it will have polyethelyne stringers encapsulated in 3 layers of 600 g csm before the floor going in. ![]() |
| I take it the blank lines in the schedule indicate a "wait for previous to cure" ? It looks a little heavy on the CSM, to my eyes. Mat isn't strong, it isn't a good structural material. It's a filler, for taking up the space between the fibres of the heavy rovings. I would think that only one layer of CSM between layers of roving should do, ie. less mat more roving. But maybe that's just me.... Is this to be cured open or under vacuum bag?
| Look at http://www.zeppelin.fr/uk/frm_fab_uk.htm. Maybe too many Mat. and this is for the Zodiac CZ7: "Hand lay-up: Hull - 54 oz. woven roving, 4 oz. chop strand mat. Deck - 36 oz. woven roving, 3 oz. chop strand mat. Balsa core in hull. 4mm. Coremat core in deck. " That's look like: Gelcoat 300 gr mat 300 gr mat 600 gr roving 300 gr mat 600 gr roving 300 gr mat 600 gr roving Quote:
__________________ Jean-Francois Blouin PS Sorry for my not so good english |
| 300 gram against the gel coat is ok I would use 450 gram instead Why use roving ??? it is thick ,it uses a heaps of resin, and you will get print through of the glass pattern .I would be using a cloth of the same weight rather than a matt its thinner for the same weight and lays flatter = less resin . Finish with roving on the inside laminant and a layer of peel ply to help sop out some of the resin off the surface and give a smooth finish . |
| RIB - 6.5 m | Bijit Sarkar | Boat Design | 4 | 06-26-2006 03:14 AM |
| Rib Hull Mold | Lewis Dunn | Boat Design | 2 | 05-15-2006 04:00 AM |
| RIB designers | royalray | Boat Design | 0 | 07-14-2005 05:09 AM |
| rib help | billboat10 | Powerboats | 1 | 05-16-2004 12:42 AM |
| rib or fibreglass? | petergcmc | Powerboats | 2 | 04-14-2004 02:33 AM |
