Old 03-14-2011, 02:55 PM
girvin girvin is offline
Rep: 37 Posts: 73
Rhino liner style covering
So I can't find the thread that had the name of the company that made a coating for marine applications similar to truck bed liner. I just got a 86 Boston whaler 19 military hull that I am restoring. The gel coat is very bad shape bc the previous owner didn't primer. The boat is banger up and i am using it only for fishing and surfing so appearance is not a concern. I wanted to use one of these coating on the whole thing after I sand and scrape. I want it to be really tought. This is a budget rebuild so money is tight but recommendations on a brand would be great.
Old 03-14-2011, 08:01 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
"The gel coat is very bad shape bc the previous owner didn't primer."
I'm not sure what you meant by this.
Low budget, don't bother with any coating, put the money someplace else where it will do more good.
Old 03-14-2011, 09:31 PM
Rep: 37 Posts: 73
Sorry fornthe bad wording. The previous owner glasses over some of the hull while doing repairs. Then he didn't primer he went strait to gel coat. There is a ton of delaming cracks. I scraped some off and it's seems fine just ugly. I sent a email to sani tread to see about there product.
Old 03-14-2011, 09:43 PM
Rep: 288 Posts: 662
No primer is used when applying gel coat over a repair, sounds like he did a poor job though.
You can clean it up, sanding for the most part to prep the surface, you can use gel coat or paint after that.
Old 03-14-2011, 10:20 PM
Rep: 37 Posts: 73
Thanks I didn't think primer was used and the few repairs I have done we didn't use anything. He was a little off to say the least.
Rhino liner vicgin Materials 15 11-12-2009 07:20 PM
Space on a cruise liner monrosm@shrewsb Projects & Proposals 1 09-13-2007 09:33 AM
polyurathane bed liner overshoot Wooden Boat Building and Restoration 1 02-28-2006 11:29 AM
Liner matthewd Fiberglass and Composite Boat Building 1 09-22-2005 09:28 PM
spray-on truck liner mike Tones Fiberglass and Composite Boat Building 9 07-03-2005 07:20 AM
