Old 02-17-2011, 09:36 AM
indianbayjoe indianbayjoe is offline
Rep: 53 Posts: 108
Resin
I have the ability to get some vinyl ester resin very cheaply but we have always worked with epoxy. The project involves plywood construction. Any thoughts on substituting vinyl for epoxy for any part of the construction?
Joe
Old 02-17-2011, 09:41 AM
Rep: 1493 Posts: 7,447
If a part is not structural, sure. Otherwise, you need a structural re-design. Hardly worth the cost savings in resin unless you are going into mass production.
Old 02-17-2011, 09:56 AM
Rep: 53 Posts: 108
Well the base structure is the plywood but how is it for bonding such as where the plywood structures intersect. it seems like it might be good for the final coating of the structure along with a layer of glass since i read that its moisture reflection is better than epoxy.
Joe
Old 02-17-2011, 10:26 AM
For tabbing it is excellent. The bond is stronger than the wood fibers.
Resin infusion and resin content sorenfdk Fiberglass and Composite Boat Building 23 05-17-2011 07:02 AM
Resin not hardening...WHY? Bill Brasky Fiberglass and Composite Boat Building 14 08-14-2010 03:31 PM
Fiberglass Cloth or Fiberglass Mat? Fiberglass Resin or Epoxy Resin? canoe42 Fiberglass and Composite Boat Building 4 06-30-2008 08:18 AM
which resin to use? jeremy5780 Boat Design 12 01-17-2008 06:32 AM
how much resin? Lew Morris Materials 3 06-22-2004 06:13 AM
