Old 11-09-2005, 09:39 AM
Brian Fredrik Brian Fredrik is offline
Rep: 10 Posts: 17
Replacing portlights
I have taken out the windows from my 1970 Ranger 26. These are Aluminum extrusions, glass and rubber gaskets. The rubber is dry and the windows leak. I am planning on replacing these with 1/4 " lexan and simply bolting these to the sides of the cabin trunk with a polysulfide calk as the "gasket". It seems that a few builders ,such as J Boat, employ this method. Is there a reason I should not do this? If not, is my approach a good one in terms of calk and lexan?
Thank you.
replacing wooden plank ajoan Wooden Boat Building and Restoration 6 11-07-2005 09:41 PM
Replacing stringer, bulkheads, floor gbaaron Fiberglass and Composite Boat Building 3 12-11-2004 12:40 PM
replacing a broken mast newbe Boat Design 4 11-03-2004 07:34 AM
Replacing an iron keel with a lead keel. Kris-Stockholm Boatbuilding 4 06-21-2004 01:45 PM
Replacing rubbing strakes grp yacht Hushinish Sailboats 3 07-29-2003 09:52 AM
