Old 10-15-2010, 06:24 PM
jimbo2010 jimbo2010 is offline
Rep: 42 Posts: 32
Replacing hatch plexi
Being the boat is only 5 years old I didn't expect to see all the micro cracks from UV breaking down the materiel, in the mid and foredeck hatches.
What is the best materiel to use to make a longer lasting replacement?
Old 10-16-2010, 12:34 AM
Rep: 3125 Posts: 9,399
Stainless steel . . .
Old 10-16-2010, 12:41 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
If you live aboard full time, this is a problem. But if you are away from the boat for most of the time, you should make hatch cozies just like the toaster cozy you have at home. Right away your windows will last 37 times longer.
Old 10-16-2010, 01:03 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
jimbo,
basically there are two choices, acrylic or lexan (polycarbonate).
The acrylic is cheaper, has better resistance to scratching, but can be cracked. The polycarbonate is tougher, scratches relatively easier, is dearer but if selected correctly (thickness)... is suitable for ocean work
as suggested above, certainly use cover for UV protection in future, and if you design them right, you cam allow internal ventilation as well. Most hatches are left closed to avoid water ingress when the vessel is left, but with a bit of ingenuity, you can leave them in the half locked position and allow good ventilation as well as water security.
Old 10-16-2010, 05:51 PM
apex1
Most likely the cracks are made by you, not by UV radiation! When you use cleaning agents, containing alcohol, it causes these microcracks.
Replace with Lexan, as Lubs recommended.
Regards
Richard
Old 10-17-2010, 04:34 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
hatches as well as covers, flyscreens, blinds, come in a variety of models and pricing
Old 10-17-2010, 05:00 AM
Rep: 42 Posts: 32
Nice!!!
Old 10-17-2010, 07:53 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
My vote also goes to polycarbonate- in this case Lexan MR10, which adds a scratch- and UV-resistant coating with a ten year warranty. The same warnings about cleaning with solvents apply to MR10 as to ordinary Lexan, and because of the scratch-resistant coating, you can't heat-form it into complex curved shapes
Hatch covers are also a worthwhile idea.
Old 11-14-2010, 07:52 AM
Delane's Avatar
Delane Delane is offline
Rep: 37 Posts: 86
Diamond Plate Aluminum
If lighting is not an issue, you may consider using Diamond Plate Aluminum instead of Lexan etc. I know a guy who just replaced two hatch lenses on a Hunter 33 that has 11 port windows thus allowing ample lighting in the V-berth and Main Salon. They were cut, trimmed and fitting using only Sikaflex. I can sent pics if anyone wants to see the result. Solid, great footing and really makes it look robust. Although a little on the industrial side, but us guys like that anyways, right?
Old 11-16-2010, 08:27 AM
yipster's Avatar
in anoher case for cabin windows i asked a leading i-net shop for advice on colored poly windows with wipers in sunny conditions without a reply.
bended glas is expensive, dont really fit the sides and makes it top heavy, really think there must be a good poly alternative but might be wrong..
Hatch designs simon Boat Design 2 11-16-2008 08:34 PM
Plexi-- Cast or Extruded nassaw Materials 5 10-14-2005 06:06 AM
need hatch demension help eric352 Sailboats 0 01-20-2005 09:51 PM
Deck Hatch drs3317 Marketplace 2 12-29-2004 09:05 AM
Hatch Patterns Willallison Software 2 01-29-2004 10:05 PM
