| Replacement Core Material The companionway hatch in my fiberglass sailboat is becoming soft and on opening the fiberglass shell I found the foam core material is crumbling away. Some locals have suggest replacing the core material with plywood but that would certainly add some weight. Any suggestions for a long lasting, lightweight, stable core material for this type of repair. Thanks |
| How much core is damaged? If it is significant then foam or balsa is the favorite, if it just around the edge I usually seal the remaining core after drying it, then fill with thickened epoxy.
| Looks like it will be a full replacement of the foam core. The original material just crumbles. Thanks for your comments. |
| CoreCork core material | groper | Materials | 21 | 02-08-2012 10:50 PM |
| What kind of Core material should i use? | VashonMike | Boat Design | 9 | 12-14-2010 05:18 PM |
| New 'foam' core material? | Stumble | Boat Design | 33 | 05-31-2010 08:11 AM |
| which core material ? | aldo | Boat Design | 8 | 10-26-2005 07:37 PM |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 06:20 PM |
