Old 11-30-2006, 06:40 AM
paularey paularey is offline
Rep: 10 Posts: 32
Removing oxidation from an aluminum mast…?
Just getting ready to clean up my bare aluminum mast and I was looking for any suggestion on what over the counter (in Central America) product might work best. I would like to give it an acid bath of some kind followed up by a light polishing and waxing. I have had many suggestions from Drano to Vinegar given to me but I’m open to more suggestions if they have a practical application. Much thanks in advance for any input.
Old 12-01-2006, 09:53 PM
Rep: 505 Posts: 1,658
osfo is used on steel but dont know about aluminum,,,maybe they make a product for aluminum ,,also baby oil cleans aluminum
Old 12-07-2006, 10:47 PM
Rep: 1397 Posts: 7,215
The metal sponges with soap for cleaning pots work really well. (brillo pads)
Old 12-08-2006, 03:12 AM
dimitarp dimitarp is offline
Rep: 19 Posts: 89
For cleaning of aluminium mast from rust you can use the follow solutions:
1. 50 % water
2. 50 % solution of (40%) nitric acid.
The time of acting of this solution must be no more than 30 seconds.
Old 12-09-2006, 11:42 AM
Any corrosive cleaner will attack and weaken your mast. It is an alloy, and some of the metals are more electrolitically stable than others. This means that an acid will remove more of some metals. Also, it will penetrate any porosity or pitting and create a bigger cavity. Another problem is that it will get behind fittings, rivets and screws where it will also corrode the metals and weaken them. Polishing the mast mechanically is the safest way.
Old 12-09-2006, 02:19 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
Hear Hear.
And eaven polishing the mast mechanically is not recomended by me.
Old 12-09-2006, 11:26 PM
Rep: 95 Posts: 462
+dont know if this will be any help to you , but i polish alumium with tin foil , take a piece of the foil and place the shinny side to the alumium and rub the foil hard the shine on the foil will transfare to the dull metal better then any polish, make sure u dont use nonstick foil the cheap stuff is the best, sounds crazzy i know
Old 12-12-2006, 04:43 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
see this thread Removing oxidation from an aluminum mast…?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 12-14-2006, 11:42 PM
Rep: 2891 Posts: 8,792
Penetrol (an oil based conditioner for alkyd paints) will remove the oxidization (with elbow grease and ScotchBrite pad if necessary), though as mentioned, the oxidation is aluminum's natural protective coating. Rub on, scrub as needed, then buff off. The remaining residue can be left in place to offer some protection (or removed), though it will not last as long as paint or other commonly employed aluminum finishes. On heavily oxidized material, you'll have a fair amount of scrubbing to do with most products, including Penetrol. The benefit of Penetrol is it's non-abrasive, restores luster, offers some protection, low cost, ease and safety in use, compaired to some other products.
Removing oxidation from an aluminum mast…? paularey Open Discussion: All Things Boats & Boating 11 12-14-2006 11:44 PM
50' aluminum mast for sale mariner 40 Marketplace 1 04-02-2006 04:12 PM
Removing Seats from Aluminum Jon - Strength Issues LarryJ Metal Boat Building 2 08-11-2005 03:33 PM
Removing silicon caulking on aluminum Jack D Davis Metal Boat Building 9 03-07-2005 11:42 PM
aluminum grade for mast fritzdfk Metal Boat Building 6 08-10-2004 06:16 AM
