| Remove single pack paint applied to two pack substrate I need to repaint a plywood dinghy (Jack Holt Heron). The original but tatty paint job was two pack Northane. It was overcoated with single pack International. To apply another coat of two pack, I need to remove the single pack. Can anybody recommend an alternative to getting down and sanding it? Thank you. |
| How about paint stripper ? You may get lucky and find one that attacks the one-pack ,and not the underlying 2-pack. Maybe a pressure cleaner to assist the process after the paint stripper has softened it up, scraping is hard work. Or just stick to the one-pack recoat, saves a lot of work and will look and perform well. I'd imagine dings in ply won't be any less noticeable in 2-pack. |
| Pressure cleaners have to be used very cautiously on wood. They can break the wood fibers and glue joints. A stripper may work, but you should consult the manufacturer for compatibility. It could deteriorate the Northane and make the finish coat blister and peel.
__________________ Gonzo |
| Just sand , prime and paint. |
| Not always... take some two part thinner on a rag and wet an area of old paint. if the old finish wrinkles you must remove...if not sand prime paint. |
| Mr. Efficiency, you are spot on, I plan to go back to two pack. If I sand off the single-pack, I will have to completely eliminate the material, including any particles left behind in the abraded surface. Michael's suggested use of thinners, might achieve the necessary removal. Thank you, all for your suggestions. |
| flat-pack plywood kit? | srimes | Wooden Boat Building and Restoration | 2 | 06-23-2011 01:12 AM |
| Stuffing Box re-pack break in? | 7228sedan | Inboards | 5 | 06-14-2011 07:05 AM |
| Sealers Trapped in Ice-Pack | timgoz | Open Discussion: All Things Boats & Boating | 60 | 04-30-2007 07:01 PM |
| 1972 Pack Boat 10 Ft Folding Boat | namor | Fiberglass and Composite Boat Building | 0 | 08-29-2006 07:15 AM |
| How to remove paint from the hull of a riveted aluminum boat? | whalepass | Metal Boat Building | 3 | 04-24-2006 09:23 AM |
