Old 05-09-2011, 02:31 PM
horsinaround930 horsinaround930 is offline
Rep: 10 Posts: 2
Refinish
So I bought an old coronado 25 sail boat that needs a lot of love. the most important part of the boat that needs attention is the fiberglass. it has two spots in the fiberglass on the top half that need repair. Nothing too serious just lets in rain water. I have never used gel coat before but I have made quite a few parts for my motorcycle with fiberglass. My question is, do you have to spray gel coat? I do not have the tools or the facilities for spraying but know it has to be coated in someway. Also I would like to refinish the whole top half of the boat without having to spray anything. Is there anyway around spraying and what would be your suggestions?
Old 05-09-2011, 07:49 PM
Rep: 3125 Posts: 9,399
Paint is your best option, rather then gel coat. I've seen very few back yard gel coat jobs that turned out well. Paint is a much easier set of techniques to get a handle on, particularly in the "primitive" conditions, usually found in a driveway repair job. A solvent base LPU is the best, though costly and also the hardest to apply. A single part polyurethane would be next on the list, which is considerably cheaper and much easy to work with, next would be the WR-LPU's, the water based polyurethanes, which I dislike quite a bit, but some have had good success with. The nice thing about paint is you can match anything and the prep is straight forward.
Old 05-10-2011, 09:24 PM
Rep: 10 Posts: 2
thanks I will keep this in mind. I've been using the internet to find different processes I just wanted an opinion from those with plenty of experience.
Molded Nonskid: how to refinish with out sanding ? pescaloco Fiberglass and Composite Boat Building 7 02-02-2011 10:07 AM
How to refinish aluminum window frames pescaloco Metal Boat Building 17 03-07-2010 08:48 PM
Complete Refinish of an 86 Valero....Need Help Please!! nbvelaro Boat Design 2 05-23-2007 09:43 AM
Douglas Fir Mast. CPES - use in restore/refinish? Robert Miller Wooden Boat Building and Restoration 2 09-13-2005 01:38 AM
Spruce planked refinish questions GarveyGuy Materials 3 07-01-2005 03:47 PM
