Old 05-31-2003, 02:09 PM
Peter_T Peter_T is offline
Registered
Rep: 10 Posts: 38
Re-"Kittyhello" hatch cover project:
Ref: Folding hatch cover design problems originally posted in "sname". Additional viewing information in re-constructioned 3d redering 4 viewport may help to identify problems visually and is presented to the source persion and for viewers additional comment.
Problems critical for tearing of the horizontal gasket at the panel #2 and #3 mating joints, due to reverse travel of the hatch covers in straightening the pivot link lines. Suggest to reapply seals at the vertical rim webs. Also, the original configuration imposed a stowage problem in webs crushing the adjacent panel when in the upright position. Additional longitudinal girder needed to be implemented. Possible increasing the elevation of track to lift panel off the gasket at the initial opening condition may be considered.
Reducing scantling by trimming the deep webs may also help.
Peter
Old 05-31-2003, 03:31 PM
Registered
Rep: 10 Posts: 38
The 3d file did not complete transmission, due to over capacity on 1.25 to 1.5 mb. The 2d view still can identify the problem.
Old 06-01-2003, 10:52 AM
Registered
Rep: 10 Posts: 38
Continued to insert the 3d file.
File open in volo view. You can download from Autodesk (free).
All views are in one file for wireframe display. The file size is very small, like a picture file. Transmission permitted in .dwf format.
Thanks to Jeff's input.
However, the surfaces on solids does not display. So it has lesser visual effects compared with .dwg files.
Peter
Old 06-01-2003, 12:13 PM
Registered
Rep: 10 Posts: 38
Retransmit with binary normal.
Old 06-01-2003, 12:42 PM
Registered
Rep: 10 Posts: 38
Thanks to Jeff's input:
Also thanks to Yipster's earlier reply to file transfer topic:
Verifying the opening status of the download able files. These files are down to 20 kb to 60 kb now and does not hold up the system both at the terminal and at the network.
These files were opened with blank sheets. Wondering what to do. It may be a minor configuration problem. Files are open through right click to file and select "save as web page" to ....location can be selected to "desktop". Now, they are viewable in Volo view. It is better to have volo view resident to respond to open the files.
Peter
COCKPIT Floor HATCH drs3317 Fiberglass and Composite Boat Building 1 04-03-2005 08:27 PM
1956 ChrisCraft Project, your opinion please... PeterH Wooden Boat Building and Restoration 13 03-20-2005 06:53 AM
Ex. Seaway Group/J&J Design/Bavaria Yachtbau Project Manager available world wide. catweaselcat Services & Employment 1 12-06-2004 11:15 AM
Project managment/Design job available? Turkey and/or multihulls preferred. catweaselcat Services & Employment 0 11-20-2004 04:06 PM
Yacht Interior Project Managers (X2) Daniel Fenton Services & Employment 0 10-31-2004 07:50 PM
