| quick/simple question will liquid nails eat up/disintigrate polystyrene? |
| Depends on the type. Liquid Nails makes a glue for foam.
__________________ Gonzo |
| I've always wanted to use this but I worry people will take offense, but I think you'll be allright with it... Samhttp://www.just*******googleit.com |
| I use PL caulk tube adhesive to glue polystyrene to aluminium hulls and plywood. No problems yet (8yrs. +) I once used LN to build some wood truses. They came apart, so I quit using it. It crystellized. YES, everything was dry, clean, etc.. The faukt was clearly LN. Maybe a bad batch, as I bought a seald case and used no other tubes. |
| SamSam, That is prob the funniest **** I've seen on a forum like this! You can bet your @$$ I'll be using that somewhere else! I did in fact, for the record, google it. I did see that they had a product for foam uses but wasnt sure if that meant all types of foam. I guess it does. Thanks for the replies guys! |
| simple question | Leron | Software | 4 | 06-16-2007 09:56 AM |
| quick question about bondo | inthegarage | Fiberglass and Composite Boat Building | 41 | 10-01-2006 10:05 PM |
| simple question | bevan | Boat Design | 3 | 03-21-2004 10:04 AM |
| simple Question | huw | Boat Design | 1 | 03-04-2004 05:40 PM |
| Have simple question | Sgray | Boatbuilding | 7 | 10-28-2002 11:28 AM |
