Im painting today.
Build your boat, fair it with epoxy filler , board sand to a high standard, then give the entire hull a coat of pigmented epoxy to seal the porous fairing compound. The pigment is very helpful for building colour. . White pigment if you boat will be white, grey if your boat will be a dark colour.
Now sand the pigmented epoxy with medium sandpaper...180 0r 220 to knock off the gloss and give a tooth. Next roll on one coat epoxy primer , 545 awlgrip is good,...waite two hours and roll on a second coat of 545 primer. Primer does not brush well..roll it on. Let this two coat paint system cure hard then carefully, gently BOARD SAND the primer with 280 or finer paper. Carefully sand. fine or very fine sandpaper. Avoid sanding thru the primer. Primer sands very easily.
Next wash the entire boat with soap and water.
While hull is going from wet to dry', carefully observe the surface for any low spots. They will stand out during the drying cycle. mark these low spots and fill with one or two additional coats of primer...sand flat with a board or block and very fine paper .
Wash the hull once more with soap and water. Tape off the topsides and paint...roll and brush ...one coat of 35 percent thinned Awlgrip topcoat. Allow to cure then fine sand this first coat with 340 paper and apply the final 40 percent thinned top coat.
When working inside in a controlled temp , you may be able to reduce the thinner to 30 percent. Try on first coat.
To get good results the topside paint..awlgrip...must be very thin.
With best practice the result will be glass like.
Underwater surfaces need antifoul instead of topside paint.
Choose a hard antifoul.
