Old 03-24-2011, 02:30 PM
Rep: 3125 Posts: 9,399
The WR-LPU's from System Three can be difficult to apply in some conditions and are quite costly. They can be buffed to a high luster once cured and are fairly durable. I've never been able to successfully spray this type of paint as it dries so fast it hits the surface as powder. Given a choice between the preformance, cost and application ease between the solvent based LPU's and WR-LPU, I'll take the solvent based stuff every time.
Old 03-24-2011, 03:12 PM
etott etott is offline
Rep: 10 Posts: 19
after some research I think I will use the "roll and tip" method..
Im not sure of thetype of coatings on the boat now so I think I need to use single part paints...
Anyone have experience with blue water products:
http://www.ipaint.us/blwamatopa.html
thanks
Old 03-24-2011, 03:24 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Smart choice. Roll and Tip is being done on new megayachts with finish to rival any spray job. I'm doing roll and tip with the wife tipping when we're done.
Kurt Hughes was right about this place.
Old 03-24-2011, 03:50 PM
Rep: 670 Posts: 2,457
Im not sure of the type of coatings on the boat now so I think I need to use single part paints...
thanks
Dont know the brand. Best to visit your local boatyard and ask what system the paint gang preferes for roll and brush application . Controlling the wet edge is important when rolling and brushing. Some paint systems dont allow good wet edge time. Also purchase the roller sleaves that the yard painters prefer.
Ive have very good luck rolling and brushing Awlgrip products. The paint is shockingly expensive. Short nap or foam skinned high quality rollers work best.
Ive also had good luck with products from International and Sterling.
http://www.detcomarine.com/toc.htm
I used the System Three waterbased polyurathane for an interior project and found it nice to work with.
Above the water line paint,No primer? wrbowcal Boat Design 2 02-02-2011 02:56 AM
1-part Topside Primer over 2-part Primer stan54 Fiberglass and Composite Boat Building 21 12-16-2008 01:06 PM
1-part Topside Primer over 2-part Primer stan54 Boat Design 0 04-24-2008 09:45 AM
do i need to primer before paint? revshot Fiberglass and Composite Boat Building 5 03-19-2006 12:29 PM
Primer or paint instead of gel coat in a mold Doug Lord Fiberglass and Composite Boat Building 5 04-29-2005 07:53 PM
