Old 12-20-2005, 09:53 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Pressure treated yoods
Is anyone using PT woods in any part of there construction?
The new formula, ACQ? What adhesieves & fasteners are you finding satisfactory?
Old 12-20-2005, 12:58 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
The pressure has crushed the cell walls in the wood, so it's like a sponge.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 12-20-2005, 03:45 PM
Rep: 1397 Posts: 7,215
There are several adhesives that work well. It depends on what you are building. Liquid Nails and other solvent based glues adhere very well. The lumber is usually waterlogged because of the process. I don't believe there is any cell crushing. The pressure only accelerates the capillary action. The Wood Institute doesn't list PT lumber as weaker. The new type is treated with borates. They are not as corrosive as the older copper and arsenic salts.
Old 12-20-2005, 03:58 PM
Raggi_Thor's Avatar
OK, maybe it's just Norwegian popular beliefs, the crushing I mean.
www.MBOATS.no
Old 12-20-2005, 11:25 PM
The pressure is only about 15 PSI-103Kpa
Old 12-21-2005, 02:54 AM
Raggi_Thor's Avatar
OK, when you buy this kind of wood here it's so soaked it barely floats in salt water. When you use it to make an outdoor floor the planks shrink 5% or so.
www.MBOATS.no
Old 12-21-2005, 09:58 AM
ted655's Avatar
Rep: 122 Posts: 641
We use it alot here in Louisiana. It drys pretty well after a month (IF it's off the ground) of exposure. It has some shrinkage, but not as much as you report. The problem is the change from the old formula to this new one. I have contacted 6 adhesive manufactures & none of them will garuntee their product to adhere to the new PT woods. the wax content is too high in the new formula. Florida building codes require only hot dipped galvinized or SS fasteners be used. This stuff eats aluminium & electroplate coated fasteners like candy. If used around or in saltwater, the SS will also be eaten away. This new PT is nasty stuff.
I've only heard of 1 supplier of Borate treated wood & it is SUPER expensive.
I was hoping someone had found an adhesive they were confident with.
sail aerodynamics Hydrodynamics and Aerodynamics 470 11-28-2011 09:27 AM
Harmonic pressure distribution Van Nostrum Boat Design 42 11-11-2005 12:43 AM
Epoxy and pressure treated wood ted655 Materials 2 07-20-2005 06:52 PM
Transom vs. V Shape for Catamaran Stern Hull Free Pirate Boat Design 15 03-17-2005 07:16 AM
Replacing stringers and floors crum731 Fiberglass and Composite Boat Building 4 03-10-2005 06:08 PM
