Old 07-09-2007, 09:17 PM
mcattac mcattac is offline
Rep: 10 Posts: 2
Pressure Treated Plywood???????
What's better?
Marine grade or pressure treated plywood.
I have bought an older 18' Starcraft aluminum bowrider and the floor is spongy and needs replacement.
My plans are also to rebuild the transom.
BTW, it currently has an outboard and it will stay this way.
Thanks.
Mac
Old 07-09-2007, 11:52 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 159 Posts: 560
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Check the WIKI
Take a look at:
http://www.boatdesign.net/wiki/Mater...e-Treated_wood
where this has been discussed some.
I used well-dried 3/4" PT Plywood in replacing my transom 5 years ago, and it bonded well with West Epoxy.
Regards, Terry King ...On the Red Sea at KAUST
Old 07-10-2007, 09:41 AM
SamSam SamSam is offline
Rep: 222 Posts: 1,132
But but but PT plywood will corrode aluminum like meth does brains. If you can isolate it from the boat with innertube rubber or something, that might work. You still have to be carefull about what fastenings you use.
Old 07-10-2007, 10:25 AM
TerryKing's Avatar
On the Red Sea!
Rep: 159 Posts: 560
UhOh
Thanks, Sam.. I didn't notice the aluminum issue.
If the PT is well dried, AND has a couple of coats of epoxy wouldn't it be pretty inert??
Anyone done this on an aluminum boat??
Old 07-10-2007, 04:07 PM
alan white's Avatar
alan white alan white is online now
Rep: 590 Posts: 2,640
PT ply is not the same as it used to be. The safer chemicals (replacing arsenic, etc., have made the more recent PT more corrosive to less noble metals. I believe the problem is due to copper content. For example, building a deck onto your house in the old days, you would use galvanized nails, but now only stainless or ceramic coated screws are used. the zinc coating on galvanized nails will be eaten away in no time flat.
If encapsulated, use copper (not aluminum) drain tubes and do careful work. Transom pads should be something like stainless. In the end, care taken will pay off in keeping moisture out anyway.
Alan
Planing pressure messabout Boat Design 4 05-18-2006 12:01 PM
Pressure treated yoods ted655 Materials 6 12-21-2005 09:58 AM
Harmonic pressure distribution Van Nostrum Boat Design 42 11-11-2005 12:43 AM
Epoxy and pressure treated wood ted655 Materials 2 07-20-2005 06:52 PM
Pressure test RDB Metal Boat Building 6 08-12-2004 11:30 AM
