  #31
Old 01-05-2006, 11:05 AM
wet-foot wet-foot is offline
Rep: 10 Posts: 175
of course it must be suitable for marine use. the 16lb density is hard and brittle
but not the lighter weights. also, polyurethane gives off less toxic gas when burnt then wood frame, think it is something like 20 minutes escape time before death.
  #32
Old 01-05-2006, 12:48 PM
Kiteship Kiteship is offline
Rep: 81 Posts: 136
It always makes me nervous when a conversation starts out with "of course..." It almost always isn't so. ;-)
To the best of my knowledge, pourable foam is not available in 16 lb/ft density. This would be extremely hard foam--harder than any hardwood. Pour in place is usually called 4 lb foam, and in fact expands to between 4 and 7 lbs density (an earlier poster cites 7.5 oz in a half-gallon can. This would equate to about 7 lbs./ft.)
"Marine use" covers a large amount of ground. PU foam is perfectly suitable for docks, insulation and floatation. It is widely used as upholstery stuffing, and as spray-on insulation for fishboat holds. It is manifestly unsuitable for structural use, as for foam-core glass or carbon hulls. It is brittle and friable; quickly delaminates and separates from the glass skins. Proper boatbuilding foams like Divynicell or Klegecell and many others are far, far superior.
As to fire retardancy; yes it is possible to add fire retardants to urethane foam which raises its combustion temperature. I am not aware of any ordinarily-available pour in place "marine" foams which are fire-rated, however. My point was not about flamability of such foams, however, but about their toxic outgassing, which happens at much lower temperatures. Talk to any firefighter, ask him which is more dangerous; polyurethane foams or pine.
Dave
  #33
Old 01-05-2006, 12:53 PM
Rep: 81 Posts: 136
Here's a material safety data sheet for pour-in-place foam. Note the firefighting recommendations: http://www.fibreglast.com/documents/366.pdf
  #34
Old 01-05-2006, 07:32 PM
Rep: 10 Posts: 175
pourable foam
http://www.shopmaninc.com/foam.html
16 lb. can be had here!!!!!!
http://www.swdurethane.com/SWDpages/...g_schedule.pdf
won't kill ya as fast as burning wood.
Can't imagine there's a company anywhere in the world building trailers with polyurethane, my guess is they'd be using the cheapest foam possible like the rest of the material they use in those things.
Goodness, if a burning trailer got sucked up by a tornado it would look like a giant flaming marshmello flying through the air.
  #35
Old 01-05-2006, 08:12 PM
Rep: 81 Posts: 136
Whatever,
What will you use 16 lb 2-part foam for? They build daggerboards of 10 lb foam, and that's very, very carefully manufactured to exacting tolerances in order to deliver precisely engineered performance. What could you possibly build, needing this hardness but without any quality control, that you'd be willing to pay this outrageous price for ($53/cubic foot)?
And then you've got a foam manufacturer's study showing I will die almost 12/100 of a minute later of PU foam gassing in a fire than of wood. Unspecified species of wood, unspecified foam content, unspecified test conditions, unspecified temperature. There are wood species whose dust will kill you at room temperature, but yep, you got me.
But nevermind, you win the bet. Nice Google work. Good luck with your, er, project.
Dave
  #36
Old 01-13-2006, 09:40 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
This link may help you
http://www.foampower.com/products/slow_rise.html
  #37
Old 01-13-2006, 11:42 PM
Rep: 10 Posts: 175
Pourable Polyurethane Foam
the slow rise looks interesting for floatation, thx.
  #38
Old 07-16-2008, 12:11 AM
wannasail53 wannasail53 is offline
Rep: 10 Posts: 8
2 1/2 yrs later has anyone tried the slow rise foam yet?
  #39
Old 12-17-2009, 05:43 PM
T-Topless's Avatar
T-Topless T-Topless is offline
Drop your top!
Rep: 10 Posts: 14
Final Results of 1 years test (2/05 thru ?) ??
Bob,
What were the final results of your 2-part foam submerged in a salt water lobster tank for a year?
What type of foam did you use?
We're looking at filling the hollow keel in a Trojan Sportfish, which tends to hold smelly water.
Thank you in advance,
Captain Ross
Originally Posted by nassaw View Post
Brian,
I'm in the process of testing this foam as I post. I've had several questions on the foam after deciding to use as a filler in my dual rudder set-up on my 40' cat. Seems many out there don't understand the definition of closed cell so I'll post the IRC (Institute for Reasearch and construction) Post in the Canadian digest.
http://irc.nrc-cnrc.gc.ca/cbd/cbd166e.html
I mixed a small amount today. 6oz of pourable foam and a equal part 6 oz of activator and let it cure. Photo below. This amount produced a little more than a 1/2 gallon container. I plan to let it cure for 24 hrs and weigh the piece on a digital scale. I then plan to sebmerse just below a mooring ball in a salt water situation. Only water that doesn't freeze up here. I hope to leave it under for 2 months retreiving once a week for a weight measurment.. I can keep you postd if you like
Regards
Bob C.
___________________________ Captain Ross
  #40
Old 12-18-2009, 07:31 AM
nassaw nassaw is offline
Rep: 10 Posts: 36
Capt. Its been awhile since I started this test but remember it very well. I placed the foam in the tank for a year and then pulled it out held it in Maine weather for several months to return it to the tank for 6 more months. Trying to simulate on the hard over a nothern winter haul out. My test results record that this stuff is bullet proof for a boatbuilding material. A little tricky to use. Leave plenty of room to expand. Purchased it through Fiberglass Coatings down in St Pete Fla. I also used the 8lb per sq ft. Site posted below
http://www.fgci.com/
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 07:26 PM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 08:19 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 06:21 PM
Foam substitution---PAR? johnsonmtz Materials 2 04-24-2004 09:48 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 06:45 PM
