Old 03-20-2011, 05:10 PM
caiman caiman is offline
Rep: 57 Posts: 62
Poor man's Peel Ply
I apologies if this has been done before,but,can anyone point me towards a 'kitchen/backyard'version of peel ply please?Something that you could find in a shop, at a seaside resort ,where the nearest McDonalds is 60 miles away?
Thanks for any help.
Cheers
Old 03-20-2011, 05:28 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
I have used a #1 perforating Roller on 2 mill plastic sheeting before and it worked ok,Nothing replaces Real Peel ply though.
Slippery when wet.
www.cheetahcat.com
Old 03-20-2011, 06:24 PM
Rep: 3125 Posts: 9,399
Rip stop nylon is just as effective and a lot cheaper the peel ply. Fabric stores carry it.
Old 03-20-2011, 07:04 PM
Rep: 84 Posts: 661
I have used the rip stop before,It was Sunday night and I had to finish ,the fabric store was open earlier and I was good to go .
The funny green.
Slippery when wet.
www.cheetahcat.com
Old 03-20-2011, 11:37 PM
mcollins07 mcollins07 is offline
Rep: 156 Posts: 206
Peel Ply is essentially a Nylon Taffeta, so ask for Taffeta at the fabric store also.
You probably want a very loose weave, which they might not have. I've used nylon net which will work in pinch, but leave a rougher surface.
Old 03-21-2011, 12:05 AM
Without getting too technical about fabric types, what you'll find in nylon taffeta at a fabric store is the "patterned" styles of this material, such as crushed, embossed, embroidered, pinched, pleated, etc., while rip stop is usually just plain old rip stop and usually half the price too.
Old 03-21-2011, 01:34 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
This is a very good question. I am also always on the look out for "non" marine things that dont carry the marine label and consequential price tag.
Nail varnish as acetone comes to mind, much cheaper in 1 liter bottles at 1.50 US . Im not commercial so I have time.
Old 03-21-2011, 01:14 PM
Frosty, you are thinking about nail polish remover, which does have some acetone in it. Of course it's reclaimed acetone and a pretty low percentage too, usually about 10%, plus a bunch of other stuff, like, coloring, skin care oils, etc. Since acetone is so harsh on the skin, more and more you're seeing ethyl acetate used instead.
As a cleaning tool, it's not especially effective, usually leaving a residue, a pretty color and fragrance too. Acetone isn't costly, especially if you buy bulk. I'm paying about $10 a gallon for 100% non-reclaimed acetone.
Old 03-21-2011, 02:36 PM
Rep: 57 Posts: 62
Hi
Thanks for the replies.We don't have a fabric shop handy.I've used tin foil in the past but it's impossible to remove from the surface after being amateurly vacum bagged.I've got some ordinary nylon,will that work or does it have to be ripstop?Failing that,the polythene sheet sounds like a good idea.
Cheers
Old 03-21-2011, 03:57 PM
Polyethylene sheeting is a very good release film, though doesn't do the same thing as peel ply.
Old 03-21-2011, 07:25 PM
Frosty's Avatar
Im not stealing the thread but the acetone I buy bulk at the hair dressers supplies in Thailand has no oils or perfume in it.
Old 03-21-2011, 08:18 PM
What percentage of acetone is it and is it reclaimed? Would you even have a reliable source for this type of information over there?
Old 03-21-2011, 11:58 PM
Frosty's Avatar
Nope--just a bunch of giggling 16 year olds in mini skirts. Ive used it for some time, it cleans resin off no problems.
Next time im at the resin shop ill'e ask him what his acetone is.
Old 03-22-2011, 06:05 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
Peel Ply is basically "polyester taffeta" and is not cheap in the local dress/fabric/curtain shop but if you find the "traveller" or wholesaler, and buy in rolls from there, then the price is very reasonable (particularly if a "reject with a few flaws" as long as the weave is good and tight)... No problems... When I was building I usually bought 2 or 3 rolls at a time... (50m long and 54inches wide ???)
Try to be helpful...
Remember that there are at least two sides for every story...
Peel ply.... Roly Materials 49 12-01-2011 12:41 AM
Bog or Peel Ply? CatBuilder Boatbuilding 15 02-14-2011 04:53 PM
Perfect poor man's minumal part time Passagemaker Wavewacker Boat Design 10 10-12-2010 10:56 AM
Peel Ply on plywood/Epoxy Triman Wooden Boat Building and Restoration 5 08-17-2007 09:07 AM
Peel-Ply Removal bluwtrlynn Fiberglass and Composite Boat Building 5 02-21-2005 11:47 AM
