| Pontoon decking material Hi guys, I'm curious to find out about marine safe decking material. I am overhauling a pontoon from the ground up, and I'd like to use something other than carpet for the boat. Is there any wood, besides the expensive teak (and synthetic teaks) that would work well? I'm looking for something in the $10-$15 per square foot price range (or less!) Thank you, RadioPontoon |
| Western red cedar or luan will hold up well and they aren't too expensive. Otherwise, Port Orford cedar or atlantic cedar or cypress are also rot resistant and reasonably priced. |
| Thank you for that information. PLEASE don't laugh, but would something like this: http://www.lumberliquidators.com/cat...bCategoryId=58 be appropriate for flooring on top of the marine grade plywood? |
| since when has a pine been a hardwood............
| Haha, yeah I found that funny too ![]() So, would hardwood floors like this make for a suitable pontoon deck? Would there be a big worry about the floor buckling after exposure to water? And would the weight of the floor be too great for the pontoon? |
| Black locust is the timber of choice when you like to avoid Teak. Lauan is not worth talking, and carpet a killer! Regards Richard |
| Heavier pieces of Lauan have good properties, like spanish cedar, but overall, WRC is the best choice. No, prefinished flooring is a crazy choice due to the finish having been applied for one thing. Best to oil whatever deck material you choose unless you paint, which is my recommendation, but paint the underside as well if you do. Richard is right about carpet. Silly on a boat. |
Black Locust is a very durable, hard and long living deck. Regards Richard |
| Definately avoid the composite wood flooring or coated wood flooring materials, they are all designed for indoor use, the UV would destroy the top coats in weeks, and the glues are simply not designed for outdoor decking. One of the best cheap materials is form board, used to frame up concrete prior to pouring, it has a redish/purple coating on the both surfaces and needs protection only on the sawn sides. Carpet is nice to live with on a pontoon, just remember that it will have to be replaced every few years, and it is a devil to clean. Use ones that allow the carpet to dry easily, looking after the plywood underneath better. It works well here in Brisbane, maybe not so in other climates of course.
| So, how do you go about getting this nice wood? Do we need to buy it rough and mill it down ourselves? |
| ...the form board I am referring to is a plywood sheeting, available from any decent hardware house.
Port orford has a very good rep. in northern Europe for example, Locust a far better, WRC is known as a nice planking, when perfectly protected, but not as a timber to live on a deck. There are too many differences, I guess when we are talking the same name, we are not talking always the same timber (or quality). Regards Richard |
| Re-Decking Pontoon Boat | dahanluke | Boat Design | 10 | 11-20-2008 07:19 AM |
| Mahogany Decking Material | Ben Biron | Wooden Boat Building and Restoration | 0 | 12-13-2007 07:16 AM |
| boat material / furniture material | bogeyinthekeys | Materials | 7 | 09-10-2005 08:29 AM |
| wholEsale ipe decking material help with this sites | jakeER | Materials | 0 | 06-18-2004 03:47 PM |
| Composite decking | Busted Knuckle | Wooden Boat Building and Restoration | 4 | 06-02-2004 02:58 PM |
