| Polyethylene holding tank Hey All, Does anyone know how to weld/glue fittings to polyethylene tanks? I usually use thru-hull fittings with lots of 5200, but I really don't like how that looks. There's got to be a way! Thanks, Terry |
| Around my neck of the woods there is a pretty healthy fishery, and all the fishermen and processors use polyethylene fishboxes. When they break 'em or run a front-end loader through 'em, they call a local company that specializes in welding polyethylene. I suspect that your Gulf shrimp fishery uses the same type of fishboxes, and I bet your local processor would know someone who welds poly. Ask down at the fishplant. |
| Welding plastic isn't hard, but as in all welding, requires experience to do correctly. A heat gun, some rod and a respirator (you don't want to suck this stuff into your lungs) should get it done, but take MMD's advise and find the local folks who do this for a living. I don't think it's something that can be learned on a Saturday morning so you can have at the tank in the afternoon. |
| epoxy fuel tanks | Boatbuilding | 24 | 08-14-2008 04:36 AM | |
| Fuel tank inquiries. | Hou-Chap | Fiberglass and Composite Boat Building | 5 | 03-04-2005 09:02 AM |
| small polyethylene boatbuilding | gesdim | Materials | 0 | 01-10-2005 07:23 PM |
| Help with Replacing the Belly Tank in a 25' 72 Sea Ray | Bugmanx | Boat Design | 9 | 07-24-2004 10:00 AM |
| gas tank building | bushbunny | Boatbuilding | 12 | 11-14-2003 11:04 AM |
