Why Ester will not Stick
I did some research on the polymers (uncured resins) to find out the reason on adhesion between different resins.
General Classifications of Resins
Ester Group
Ortho Resin
Isopthalic Resin
Vynil Ester Resin
Epoxy Group
Bisphenol
Phenolic- Dow Den
Hydroxyphenil- Shell Epon
Dianiline- Ciba
These polymer crosslinking or hardening takes place by the addition of a curing agent. The crosslinking reaction is quite different from each other.
*Esters are held in suspension by a crosslinking agent (monomer) until an initiator (peroxide) is added to start the carbon-carbon chain reaction. The chain reaction produces water as a byproduct. Although newer resin compound eliminates water byproduct, the degree of polymerization is not so dense.
*Epoxy crosslink within the epoxy group by the addition of a curing agent (hardener). Polymerization is much dense which accounts for the good “grip” or adhesion to the surface of the “substrate” material.
Esters, therefore, will not provide a good grip on the “substrate” material as epoxy does.
There are many formulations of primer/paint/topcoat that will “grip” the “ester” family but only a few that will be compatible with the “epoxy” group except perhaps epoxy itself. That is why epoxy boats are harder to paint.
By my own mistake, I have added epoxy (primer) to the boat limiting myself to the type of paint that can be used.
Other interesting subject.
Marine Composites- Eric Green and Associates 1990
1.“Vynilester, having excellent physical properties, can provide excellent permeation barrier to resist blistering when used as an outer (wet) layer 20 to 60 mils thick” (the inner side is the “dry” side). I will assume that subsequent layer of Iso or Ortho resin can be applied over it and it will stick because it belongs to the same family group.
2. “Initiator compounds are sometimes erroneously called catalyst. It is not a true catalyst as it is consumed in the reaction” Fundamentals of Composite Manufacturing- Dr. A. Brent Strong 1989.
“ The material we commonly called catalyst (MEKP)is actually not a catalyst. It is an initiator.”- Composite Fabrication – Scott M. Lewit- Vol 18, #9, P 100.
