Old 09-22-2009, 02:28 PM
Sygeor Sygeor is offline
Rep: 10 Posts: 11
Polyester fuel tank
Also i want to make a polyester fuel tank in this boat.
Do you know if i will use the same polyester like i use in the other boat?
Give me an advice about this?
Thanks
Old 09-22-2009, 03:12 PM
wardd wardd is offline
Rep: 443 Posts: 925
ive seen petroleum products attack polyester
Old 09-22-2009, 03:32 PM
stefan.b stefan.b is offline
Rep: 37 Posts: 7
Yes, but which resin? Polyester has been accepted for underground fuel tanks (diesel oil) for mor than 40 years over here, and these tanks give you less trouble than tanks made from steel, which have to be inspected for corrosion every so-and-so many years: click!.
Another question is how polyester tanks behave in a case of fire.
Old 09-22-2009, 03:41 PM
mark775
Isothalic resin resists diesel. Make sure to coat inside of tank well so there can be no wicking up fibers. Vinylester is better. Epoxy works, too. Devoe makes epoxy tank liner coatings that many people use. I don't remember the numbers - Maybe 253?
Old 09-22-2009, 11:14 PM
Rep: 418 Posts: 777
If you are using the tanks for gasoline, be aware that some of the new ethonal blends attack the older fiberglass tanks with dire results.
Old 09-23-2009, 10:15 AM
Rep: 443 Posts: 925
this was years ago on army aircraft the different hydrolic fluids would desolve the resin and leave the cloth
Old 11-21-2009, 03:06 PM
GG's Avatar
GG GG is offline
offshore artie
Rep: -30 Posts: 190
i have a thread in the fiberglass and composite forum titled Skater 32 in which i repaired the tanks in a epoxy boat and in doing this repair i used a long list of materials because the new generation of fuels especially Ethanol is really having a bad affect .
fuel tank materials scphantm Powerboats 4 05-25-2009 04:33 AM
fuel tank question Dawgs Outboards 17 03-21-2008 07:23 AM
Fuel Tank man5 Fiberglass and Composite Boat Building 35 05-05-2006 07:28 AM
Fuel Tank Location zack Boat Design 3 05-08-2004 05:04 PM
Under sole fuel tank Arko Wooden Boat Building and Restoration 20 02-27-2004 09:45 PM
