Old 09-13-2011, 11:37 PM
Michail Michail is offline
Rep: 15 Posts: 54
Polyester basics
I pretend to build a single skin hull using isoftalics poliester resin, and for the most part it will consist of a 300 mat, followed by three layers of (Mat 300 with roving 600).
The main question (may be quite obvious for some) is what the sequence between these layers should be. The mould is about 18 m2, so that one can reasonably work through one layer (MAT plus Roving) in about 2 - 3 hours time. The gel time is about 30 - 40 minutes with the formulation suggested by the supplier (the maximum safe working time).
The local supplier suggested that I can start with the next layer without sanding, but wiping the surface with styrene monomer.
I have heard opinions suggesting that the next layer must be put almost immediately, i.e. just at the end of the gelling period of the previous layer, at most its double time, but without any wiping with styrene. And if I pass this time frame, it will be a secondary bond, and in that case I need sanding and wiping with monoesterine...
So basically the question is:
If I have a gel time of 30 minutes, and I can place the next layer not before 3hours after previous one, what is the best treatment for the previous layer (nothing, estyrene wiping, sanding and wiping). Or should one try and reduce the 3 hour time to maybe an hour by getting more helpers?
Old 09-14-2011, 01:11 AM
dialdan dialdan is offline
Rep: 51 Posts: 41
re Polyester
Hi Michael
Make sure you use unwaxed resin and you won,t have a need for sanding , wiping etc.
Cheers
Al
Old 09-14-2011, 01:32 AM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
No need to wait 3 hours to spend in the next hand. You can do immediately. This way you will win because they use less resin. But so you want many people to do it. The biggest difference in time from one side to another without sanding is 12 hours. necessarily after sanding.
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Skip the styrene wiping step.
With a straight ISO you have plenty of time to lay down the next layer and still have an good bond.
While doing the entire laminate at one time would be best, you don't need to rush the next layer, coming back the next day to finish it is fine.
Temperature and humidity will have big affect on how quickly the surface will cure to the point where the bond will be compromised. High temps and low humidity will speed the cure, low temps and high humidity will slow the surface cure.
Like has already been said, don't use a waxed resn, if you do use a waxed resin, wiping it with styrene won't help much.
Old 09-14-2011, 07:01 PM
Rep: 15 Posts: 54
I am going to use isoftalic F737 from AOC. It does not contain wax. It seems not certified for marine use, and is resilient resin for use in corrosive environments and for heavy duty piping. I was told by the tech department of the supplier that it comes closest to the use for boat building . In Chile it is impossible to find certified naval use resin, since everyone uses the cheapest stuff.
Actually, today I got an answer from tech department from AOC and they confirmed that no styrene wiping is necessary and the working window is about 12 hours between layers.
Old 09-15-2011, 01:59 AM
m3mm0s rib's Avatar
Rep: 31 Posts: 111
EXACTLY
Old 09-15-2011, 03:05 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
If you are using 300 gram chopped strand matt you will be there forever . lay 3 layers of 300 gram one after the other while each layer is still wet . 900 grams is ok Keep your catalyst so you have 40 minutes or more gel time . Work with amall areas till you get used to what you are doing and then increase the area you lay each time . If you are making a mould csm is best till you have at least 5 or 6 layers of you 300 gram down before you start and use any woven glass . Woven has a habit of showing the weave of the matt on the surface of your mould if its to close to the gelcoat . The sanding and wiping things is a waste of time just get into the job and do it !!
What are you making ????
Making beautiful boats is a passion never a chore !
lofting basics help HO229 Boat Design 59 03-15-2011 10:17 PM
Back to Basics amdega Boat Design 2 02-11-2009 05:26 PM
Difference between infusion polyester and regular hand lay-up polyester? erikssonniklas Materials 2 01-14-2008 10:48 AM
Basics for newbes ted655 Propulsion 0 07-04-2006 02:04 PM
Basics of Sailboat design flyingdutchmen Boat Design 2 10-22-2002 07:20 PM
