Old 06-12-2009, 07:52 AM
stilloutoffocus's Avatar
stilloutoffocus stilloutoffocus is offline
dealership repair flunkie
Rep: 10 Posts: 29
plywood transom/stringers?
im pretty sure i already know the answer to this one, but has anyone here had success laminating treated plywood with polyester resin and fiberglass?
most sources ive seen say that you have to have epoxy to get a good bond with treated, and we have always used regular sheathing ply with poly for our transoms and stringer jobs. but the old man say that he has had good luck laminating treated wood with poly. my boss even says that the manufacturers are now using treated ply with poly laminate for transoms now.
does anyone have any info or opinions on this?
thanks much for your input
Old 06-12-2009, 01:27 PM
Rep: 1397 Posts: 7,215
There are a couple of manufacturers of treated marine ply. I don't know if there is any difference. The new treated wood all has borates instead of copper arsenate. It is much more higroscopic (absorbs water) so I would think you got to be really careful about drying it.
Old 06-12-2009, 03:13 PM
PAR PAR is online now
Rep: 2891 Posts: 8,792
The new CA treatments that have replaced the CCA in PT products doesn't take well to polyester or epoxy.
In other words, don't use treated plywood or dimensional lumber unless you rely on a very aggressive mechanical bond.
I don't know of any manufacture that is using PT plywood in transoms or stringers. Your boss sounds typical and over stating what he doesn't fully understand.
Is there some part of my previous post on your other threads about this issue, that I didn't make clear Stilloutoffocus?
Protecting Plywood with Polyester Resin
The new PT treatments seal the "pores" of the wood, so anything trying to penetrate can't. You can "tooth" up the surface, but the bond is inferior. And yes, drying the material is more difficult then the old CCA treatments.
Old 06-12-2009, 06:07 PM
ondarvr ondarvr is offline
Rep: 226 Posts: 633
There is still CCA treated ply for marine use, it works well and many boats are made with it. Greenwood XL boat panels is one brand.
Don't have time to list more info right now.
Old 06-15-2009, 07:32 AM
Rep: 10 Posts: 29
well PAR i do remember your posts on a thread i commented on earlier and i did understand you. but you are not the only source of information on this site, and while i do value your input i feel that the only true path to understanding of an issue is to get information from as many sources as possible and find the truth somewhere in the middle. so while you obviously do have a great deal of experience and knowledge in boat building design and repair no one knows everything. and while my boss does like to act like he knows everything although most of it isnt true. he has been a sea ray dealer for the better part of 50 years and does know a little about their construction. and of course when it comes down to it i have to make do with the materials i am provided, regardless of how much i may try to enlighten my superiors to the errors of their ways.
Old 06-16-2009, 06:50 PM
Dan H's Avatar
Dan H Dan H is offline
Rep: 10 Posts: 23
Do you mean this ply? It's called powerply by World Panel Products.
http://www.worldpanel.com/marineplywood.htm
Old 06-17-2009, 07:34 AM
Rep: 10 Posts: 29
no, dan , what i was given is just pt ply from lowe's
Old 06-17-2009, 07:48 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,538
stilloutoffocus some of us wont reply (such as myself) once a very knowledgeable PAR has given an outstanding reply, i may from time to time add my 2 cents.
do yourself a favour and go and experiment
then you will also come back and say thank you PAR
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 06-17-2009, 12:21 PM
Rep: 10 Posts: 29
i thought i was clear in stating my appreciation for PAR's advice and i do hope to hear from him on future posts as well as he is, as i stated before, very experienced and knowledgeable. but. no one man knows everything about any subject, and it is my experience that there are as many methods of FRP work as there are workers. i was only trying to find as many opinions on the subject as possible.
24' Fiberform - Rotten Stringers/Transom Ehdrian Fiberglass and Composite Boat Building 103 07-25-2008 02:19 AM
Stringers and Transom - cloth weight MercMark Fiberglass and Composite Boat Building 5 06-13-2005 10:24 AM
Stringers and transom - cloth weight MercMark Materials 0 06-02-2005 02:10 PM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 03:21 AM
