| Plywood - is this stuff ok? As it says, what would this plywood be like? Everything I read mentions AC and AB grade, or marine grade. I think the WPB glue is ok, but don't know if this ply is suitable. Sorry if this seems like a stupid question, but nobody I have talked to that sells ply can be of assistance. I live in Dubai by the way, if anyone has any details of a good supplier in the area. I am looking at building my first boat, maybe a 14' dingy or something similar. I know the 18mm ply is too thick for this, but that's all I could get a photo of. Thanks ![]() ![]() ![]() |
| Oh good... they damaged a few pieces. Get a free sample and boil it for a while and see if it delaminates or does anything strange. It is one way to see if the ply is boatworthy. Another is voids in the inner plies. Maybe purchasing a whole damaged sheet for a big discount would allow some investigation? Alan |
| Were I to consider building a number of boats with Marine Ply and the MP be not available where I live, would I move? Absolutely! It is just not possible to make a silk purse out of a ---.- ear. On the other hand, with glass fibre cloth and epoxy resin to keep the water from the wood, the one boat you want to build, will be good experience and should serve you well enough. It must be epoxy and not polyester, or you'll take an early swim. Pericles |
| Matt, If you accept that epoxy does a better job, then those attributes will make up for the deficient ply available to ako in the UAE. The other side of the equation is that using top grade marine ply and polyester would result in a worse boat than if epoxy resin were used. My conclusion is that boats should be built with the very best materials, but epoxy is vital even if the hull were constructed with newsprint and egg boxes. Joubert and West will gain Lloyds approval. Pericles |
| As a general rule, hull shell materials should be the best your budget can manage. Typically, the hull planking is the best wood on the boat, for obvious reasons. |
| "Great Stuff" for flotation foam? | crasea18 | Materials | 2 | 04-23-2007 01:52 PM |
| What do you make of the white stuff? | bilgeboy | Boatbuilding | 5 | 05-05-2006 04:53 PM |
| black stuff on new steel | gonzo | Materials | 9 | 08-24-2005 08:49 PM |
| Just some stuff | Andrey | Education | 3 | 06-19-2004 09:07 PM |
| Cool stuff!!!!!!!!!!!!! | Josh | Open Discussion: All Things Boats & Boating | 4 | 09-10-2003 07:44 PM |
