Old 08-28-2006, 06:38 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Untill it gets wet. Then it's a high tech sponge.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 08-29-2006, 02:54 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Do you have any prices for that composite?
If marine plywod is too expensive, I suppose composites are more expensive.
I pay for example 10$ for low cost plywood, 20$ for marine grade Okoume plywood, and 40@ for divinycell foam. The foam then need 2x450g of bidirectional glass and the same weight of epoxy. The glass and epoxy (close to 2kg) costs another 20$...
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 08-30-2006, 01:20 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
I think it's a closed cell foam, will not absorb water. It's mostly fiberglass, that's not known for absorbing water is it?
Lots of information (2 pages so far) has been posted in another forum which I post in, pricing to. Should be the same price or close to the same price as marine plywood, and you don't have to seal it.
Link:
http://www.hoverclubofamerica.org/fo...?showtopic=883
You can always e-mail them for techincal data and prices.
http://www.coosacomposites.com/
I found out about this product at boatdesign.net, you may of heard of it.
Old 09-02-2006, 12:54 AM
SmithCraft64 SmithCraft64 is offline
Rep: 15 Posts: 57
I went to the local lumber yard today and priced a single piece of 1\2 inch 4x8marine plywood. I was a bit surprised by the $80.00 price tag. Is this the going rate for marine plywood? Needless to say im going to shop more. I will check out the links listed in the posts above also. I live in the State of California in the U.S. Out of pure unadulterated curiosity what are the prices in your areas? Marine grade 1\2, 5\8, 3\4 4x8 sheets. Thank you in advance.
Old 09-02-2006, 05:13 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
It has been 8 years ago since I bought some. One-half inch (4 x 8) went for $50 a sheet. It was not the top of the line stuff as it was for a lofting floor. I was then going to utilize it for the interior.
Marine ply comes in many grades with differing ply counts, wood types, ect... Do a little surfing and you will get a better idea of what you need to meet your needs.
TGoz
Old 09-02-2006, 06:33 PM
Rep: 15 Posts: 57
This plywood was 5 ply 1/2" 4x8 FIR Marine grade AB. I noticed it seemed dry and brittle. Does this type of plywood have a shelf life? At least to a point and depending on how long it has been stored I would imagine. This was inside there barn stacked flat. It was the last piece they had in stock. What kind of things should a boat building rookie look for in marine plywood? I have completely taken my SmithCraft down to the aluminum hull. I am replacing every bit of wood in her. I am going to replace alot of the wood bracing with aluminum gussets to lighten it up as much as possible. I'll post some pictures or maybe a link to some soon. It would probably be best to link to them. That way yawl can take a look at my latest adventure my second restoration. And a Question for the moderator. This started as a post on plywood . Should I move it somewhere else in the forums? From this post on? Let me know and I'll do just that.
thanks SmithCraft64
Old 09-02-2006, 09:33 PM
ted655's Avatar
Rep: 122 Posts: 641
Closed cell polyurethane foam is fine as long as it is not put in a situation where it migt be subjected to "constant" moisture. That would be anything below the waterline or in a bilge situation. In a perfect world (the one on paper), fiberglass is impervious to water. Then there is the real world, with all it's stress cracks, delamination, blisters, groundings, & leaks around thruhulls, screws, bolts, shaft logs, etc..
Old 09-03-2006, 03:03 PM
Raggi_Thor's Avatar
Originally Posted by SmithCraft64
...FIR Marine grade AB. I noticed it seemed dry and brittle. Does this type of plywood have a shelf life? ...
I think fir as pine will always cheek when the plywood dries.
It's a common problem.
That's one reason to use Okoume or Meranti.
For 6mm (1/4 inch) I pay 60USD per sheet (4x8 feet) of Okoume.
Then transportation may be almost the same if I buy just a few sheets.
www.MBOATS.no
Old 09-03-2006, 06:09 PM
kach22i's Avatar
Architect
Well stated.
  #25
Old 09-04-2006, 10:44 AM
Rep: 15 Posts: 57
Thank you all for your input. Im off shopping for the materials mentioned. Have a good one. SmithCraft64
Plywood Moth oceangboy2000 Sailboats 42 01-01-2006 04:20 AM
Plywood Catamaran petee Wooden Boat Building and Restoration 8 08-16-2005 01:51 AM
Looking for plywood russ lepisto Wooden Boat Building and Restoration 14 05-03-2004 07:58 AM
plywood, to seal or not willibuch3 Wooden Boat Building and Restoration 11 03-13-2004 06:57 PM
plywood scottscotland Materials 7 02-17-2004 08:25 PM
