| ply bulkheads Hi I’m currently designing a 33’ catamaran and have not been able to find information on bulkhead widths so my question to you is this. What width should my bulkheads be I have the option of 6mm 9mm 12mm or 18mm any information would be of great help ![]() |
| I AM A BIT WOORIED, sorry, caps locks whas not intended though :-) If you don't know what stiffness you need in your bulkheads, and how many you need, think about all the other things you dont know! I would say 12mm, will you then use that and go to sea? |
| Should have explained Oh, sorry it does sound a bit “out there” but no Im actually looking at a set of plans, very very old plans, and from researched information there are a lot of new techniques and materials for bonding and strengthening so Im trying to find the best way to approach and alter the designs at hand. thankyou for your reply |
| I think 12mm would be "normal" for a monohull sailboat of that size, but catamarans are stressed or loaded differently, you have enormous forces from the crossbeams, I guess.. |
| katfish I am building a 42 ft Wharram with West System epoxy, and the bulkheads are 18mm ply. I would think that for a 33 footer, 12mm would be fine. It also depends on how many there are. The Wharram has them about every 5-6 ft. |
| im building a 17' shanty boat (wich i intend to call the sea serpent'and intend to have a bulk head every 3 feet,would this be ok? |
| It's impossible to answer simple, it depends on the skin thickness and longitudinal stiffeners. With some stringers say 20x20 to 30x30mm and 6 to 9mm skin it sounds reasonable. BUT, it depends on deplacement, speed, conditions etc. |
| Are Bulkheads Necessary? | LBG | Metal Boat Building | 13 | 08-24-2006 09:48 PM |
| How to trace and cut bulkheads | ath | Sailboats | 18 | 06-10-2005 03:43 AM |
| Adding bulkheads | Ok J | Fiberglass and Composite Boat Building | 5 | 05-03-2005 12:45 PM |
| Vacuum bagging bulkheads | tbot | Fiberglass and Composite Boat Building | 4 | 03-11-2005 08:00 AM |
| absolute beginner ply/epoxy or ply/glass | wannabe | Materials | 9 | 08-13-2004 06:01 AM |
