Old 06-04-2012, 01:33 PM
pauloman's Avatar
pauloman pauloman is offline
Epoxy Vendor
Rep: 141 Posts: 146
epoxies are generally too brittle to work.
best is an aluminum moisture cured urethane (MCU) - a few coats along the seams. - only works with small leaks. goggle aluthane.
paul oman
Old 08-12-2012, 04:37 PM
Ace Dragon's Avatar
Ace Dragon Ace Dragon is offline
Polyurea and Spray Foam
Rep: 25 Posts: 25
Polyurea will do it.
Not a do-it-yourself product, but will do it. find a qualified applicator in your area and never have a leak again.
Old 08-13-2012, 04:56 PM
jonr jonr is offline
Rep: 36 Posts: 517
What's the downside to welding all of the rivets and seams? Hard to beat one solid piece of aluminum.
Old 08-13-2012, 08:23 PM
Yacht Designer/Builder
Rep: 3465 Posts: 11,657
You mean besides heat distortion opening all the seams, welding light gauge sheet aluminum, distorting the panels themselves, insuring a perfect, water tight weld on every seam and hole? No I can't think of anything other than these trivial bits of heartache.
PAR Plans
PAR Blog - fresh updates
Old 08-14-2012, 12:14 AM
Ace Dragon's Avatar
Rep: 25 Posts: 25
Unless you can do it your self - aluminum welding does cost.
sun in my screen so no telling what I will type. the boat is of thin metal more than likely, it would take a quality machine and good welder and if hired out could cost more than buying a new boat.
Polyurea project would go something like this. Carry boat to applicator. one hour for his machine to heat up, one hour to sand blast to get a min. of 3 mil profile, desalt the metal = 30 minutes = after drying it would take 30 min to spray. Cost is reduced if no masking is required - let him coat the complete out side.
You may want a different color but polyurethane paint hold well to polyurea. cost for a simple 20 ft. boat could be around $1,100.00
Old 08-14-2012, 07:51 AM
bntii's Avatar
bntii bntii is offline
Rep: 1324 Posts: 793
Ace- how is the product holding up so far in the field on boats?
Any bonding issues?
Equally good to go on FRP, steel, Al & wood?
How is corrosion dealt with on Al and steel hulls?
I did see your other thread- I will be interested to see if the how the product comes along in the recreational boat industry here on the East Coast US.
Thanks
Old 08-14-2012, 08:43 AM
tunnels tunnels is offline
old one !
Rep: 537 Posts: 3,744
search back aways !!
Some where a few months ago was the almost exact same post !! go look and see !
West system have a rubber toughtend epoxy at sticks really well and is semi flexable for just such a occassion !!
Making beautiful boats is a passion never a chore !
Old 08-14-2012, 11:55 AM
Rep: 36 Posts: 517
Some of us are good welders with the right equipment. Most of us can respond to a question without resorting to sarcasm.
PAR added to ignore list.
Old 08-14-2012, 01:20 PM
Ace Dragon's Avatar
Rep: 25 Posts: 25
No sarcasm or self promotion intended.
I received a message that I might be self promoting - Not intended. I just gave a cost as an point of info.
I think I will be leaving this site.
As to salt water boats - we desalt the metal after sand blasting.
We have created a coating that is the first to hold up to silt filled ice of Cook Inlet, and Phantom boats have been using a polyurea for a few years now for rock protection.
Polyurea can hold up quite well if substrate is prep'ed correctly.
Polyurea is a plastic so it can and has been used for electrical protection.
There are many different types of polyurea's and the correct one has to be spec'ed out.
Have fun guys.
leaky jon boat ilovefishing Metal Boat Building 7 05-06-2011 08:58 AM
Leaky injector RAMMYBOY Diesel Engines 5 04-04-2010 01:43 PM
Fibreglass to Aluminium connection amamini Fiberglass and Composite Boat Building 8 07-29-2009 07:01 PM
Leaky IMP - suggestions? smac6 Powerboats 0 07-24-2006 04:19 PM
No fun in a leaky boat Acidhouse Powerboats 12 11-13-2005 10:38 PM
