| Painting Aluminum Hi. I've designed a 15ft aluminum boat. I'm going to build it this summer but I have a big question about painting my boat so I searched and found some methods like "Anodizing" and "Chromate conversion coating". Are these methods a property of aluminum plate that I will buy or a process that I should do? If I should do this, it should be before cutting, forming and welding or after these? ![]() excuse me for my elementary questions. I'm a novice in boat building |
| You first need to acid wash and rinse with water to take the oxidation off. Then you lightly spray with zinc chromate. Spray primer and paint after. All the welding and grinding have to be done before.
__________________ Gonzo |
| Firstly, you need to degrease. Best to degrease with detergents, solvents are considered too light in that sense. Then you have 3 ways of surface cleaning, 1) etching, 2) cleaning with an abrasive jet or 3) disk grinding. Then the primer and finally the painting. |
| Thanks for your answers. Is it possible to anodize the plates before building? It seems to be less troublesome compare to doing this to a bulky boat Are these processes something that I can do my self? |
| Choose the paint you want to use and follow their recommendations for painting aluminum. Follow the instructions to the letter, aluminum is not very forgiving to paint shortcuts. If you want a good finish use a 2 part urethane like awlgrip or imron or sterling. |
| I would consider using alodine before the paint. |
| Why paint? It's aluminum, If you leave it exposed, it will never corrode away. If the boat is for your enjoyment, then save yourself the headache. Some trivia I was talking to a metalurgist a few years ago about painting aluminum, and I described the process of acid washing the hull as "taking the oxide layer off". He shook his head and said," No....no...the oxide layer forms instantly." He then lectured me. The upshot of it was that the acid wash takes off the (I hope I get this the right way around) existing, closed-pore oxidation and permits it to be replaced with an open-pore oxide layer (which the paint can adhere to). Actually sanding and brush-off blasting have the same outcome as acid washing, and they give you a surface profile to enhance the coating adhesion.
__________________ JDF '"Forward, the Light Brigade!"' -Alfred Lord Tennyson |
| Thunderhead, Just to add on. As I understand it the speed of aluminiumoxidation is so fast that it is almost instantaneous in a real world setting. It is possible to clean aluminum without this, but it takes working in a zero oxygen environment which is obviously not reasonable for boat building. However once the initial layer oxidizes it acts as a barrier to more oxidation on the substrate.
| Thanks for your replies on my question. I want to participate in jetsprint racing in Australia so we should paint it. This is our first time that we build a boat and that is why I have so many questions |
| Painting Aluminum Drive Parts | ChrisN67 | Boat Design | 6 | 06-06-2010 04:37 AM |
| How to take an aluminum boat back to bare aluminum and keep it that way. | ryanpratt | Metal Boat Building | 3 | 04-05-2010 10:17 AM |
| Painting 34' Open Aluminum Hull - Questions... | blacklab | Materials | 1 | 10-23-2007 03:18 PM |
| Aluminum boat - painting with laquer | Alik | Boat Design | 8 | 08-09-2007 03:06 PM |
| New Painting | Victor Lemmi | Sailboats | 0 | 07-20-2004 06:52 AM |
