Old 03-19-2006, 11:30 AM
huntermike32 huntermike32 is offline
Rep: 10 Posts: 10
Paint Question
I would like to paint a boat of mine and i do not want the paint to fade off. I am doing a design on the side. If i were to put a layer of fiberglass over it would i be able to see the painting and still protect it.
Old 03-19-2006, 07:41 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
The paint will normally weather better than resin or gel coat will. It is possible to apply a layer of clear gel coat over the paint, but most of the time the gel coat will attack the paint and create problems. Use a clear coat (paint) over your design, and use good paint.
Old 03-20-2006, 10:24 AM
mastcolin mastcolin is offline
Rep: 133 Posts: 100
As above.
The styrene from the resin will mess with most paints. Don't do it.
What colour do you want? Some colours will fade more than others. Choose white(off white shade) or black. They are best. In fact black is best. Don't choose red.
If you want a good job, put a clear laquer over the top (not on white, that needs a 50/50 mix).
Put plenty on.The thicker the paint, the longer it will last. Sorry, no paint is indestructible. (we'll I have actually seen one that pretty much was but it's original gloss wasn't so high - but it kept at that level for 10 years. It was an aerospace coating made from a fluoronated polymer).
To be honest, you'll do more physical damage than life of most paints. You'll repaint.
ps Keeps me in work!
paint question MilitaryPopo Fiberglass and Composite Boat Building 8 01-31-2006 09:07 PM
Topsides & Deck Paint Question Chris Krumm Materials 3 08-27-2005 07:44 PM
Antifouling Paint Question - ViViD TennesseeGuy Materials 1 05-31-2005 12:31 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 02:22 PM
Help PAint or gel this is the question Bayliner bum Materials 1 09-10-2004 12:37 AM
