Old 06-10-2006, 01:38 PM
rmcelroy rmcelroy is offline
Rep: 10 Posts: 2
Paint over spar urethane on plywood.
Hi guys, I just dropped in from a Teardrop Camper forum. I know you guys deal with epoxies, glass and urethanes all the time. I was hoping to get some advice about a question that will probably be pretty (duh) to you.
I have a Teardrop that I'm ready to put a finish coat on, I have been planning on using aluminum-but have backed out, its a long story. Anyway my camper now has one coat of Minwax spar urethane on it. I want to paint it a silver/aluminum color and would like to ask what kind of paint you would recommend.
I like some things I hear about epoxy paints but suspect I need to stay with a urethane........any sources would be greatly appreciated
Thanks for any help you may give
Regie
Old 06-19-2006, 01:11 AM
Rep: 1397 Posts: 7,215
You can use any alkyd enamel. Epoxies and two part paint will lift the urethane and crinkle it; like paint remover does.
Old 06-19-2006, 08:09 AM
Rep: 10 Posts: 2
Thanks Gonzo, I ended up going with the sheet aluminum. I sat and thought for a while and solved a couple of the problems that were keeping me away from it. Its for the best I'm not the best painter in the world and the Al sure looks good.
Thanks again
Regie
How to/best way to touch up urethane paint runs…? paularey Fiberglass and Composite Boat Building 6 11-28-2005 05:50 PM
polyester matrix over urethane foam tjantti Materials 0 09-21-2004 05:21 AM
Urethane as a replacement for Gelcoat? turnershells Materials 0 09-11-2003 11:25 AM
urethane E.V.O. Materials 2 08-29-2003 06:49 AM
Spar Varnish dcoop Materials 4 03-22-2003 12:37 PM
