Old 02-21-2010, 10:53 AM
rrrwel rrrwel is offline
Rep: 10 Posts: 8
Paint Drips - Now What?
Instead of rolling and tipping I decided to spray a couple of large cockpit panels with a 2 part poly (Alexseal). I'm new to spraying and it came out looking good but I got some drips.
How do I remove them? If I need to buff them out what should I use and how long should I wait regarding paint cure?
Thanks for the advice.
Old 02-21-2010, 02:51 PM
Rep: 1493 Posts: 7,447
You can buy a drip plane at the automotive paint supply. It looks like a miniature plane and works with a razor blade. It takes the worse off. Then you sand with 800, 1200 and buff. 3M Finesse is my favorite. Where in Wisconsin are you?
Old 02-21-2010, 03:11 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
yeppers Gonzo, and put soap on the paper and use a block, if you go really fine it,ll polish up ok
and , when you spray a 2 pac, light one coat, wait 20 mins slightly heavier then finally 20 mins later final , dont let the gun come to close, ah well lessen in spraying can be a long one, there are good topics on it here somewhere Some paints you thin up tp 60%
depending on your ambient you can use a speed cure additive too
Old 02-21-2010, 03:35 PM
The planes are only for really bad drips. If not sanding is enough.
Old 02-21-2010, 04:51 PM
Rep: 10 Posts: 8
I Live in Oak Creek Gonzo. Does it have to fully cure before trying to sand or would a few days suffice?
Rick
Old 02-22-2010, 12:32 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
A few days is OK, whoosh started on thinning, you cannot spray two pack paints following the directions on the can, they HAVE to be thinned to get a good spray job....I have NEVER seen anyone do it straight from the can and get a good job.
Old 02-22-2010, 10:06 AM
It should fully cure in a day unless you sprayed in an unheated shed. Try your fingernail on the drip. If it doesn't make a mark it is ok to sand. The worse that can happen if the paint is soft is that the paper will clog immediately. Then you know you have to wait a bit longer
Old 02-22-2010, 06:16 PM
Rep: 10 Posts: 8
Just for your info I'm using a 4 stage HVLP Turbine, if that changes anything.
Paint waterbaby Materials 0 08-10-2009 08:42 AM
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 08:45 PM
Paint Help! DeputyMike Fiberglass and Composite Boat Building 26 09-05-2007 08:56 PM
My paint has come off ! Dave-Fethiye Wooden Boat Building and Restoration 12 08-16-2007 06:15 AM
Epoxy Drips rturbett Fiberglass and Composite Boat Building 6 03-08-2007 10:10 AM
